Can I pull this off?
Old Jun 30, 2001 | 12:43 PM
slivic's Avatar
Default Can I pull this off?
I am trying to figure out if I can use this block. The head I have to use is a GSR, port and polished, and milled .020. Can I do it with a J&S, the car is daily driven.
1995 GSR shortblock. Endyn Rollerwave 81.5mm pistons. 12:5 to 1 C.R. with
B16/ Type R head. New oil pump, new water pump, all new bearings, seals, and
gaskets. less than 1500 miles on engine.
Old Jun 30, 2001 | 01:35 PM
sgT's Avatar
sgT
Default Re: Can I pull this off? (slivic)
i wouldnt try
Old Jun 30, 2001 | 03:24 PM
kenji's Avatar
25 Year Member
Default Re: Can I pull this off? (sgT)
I have seen an ITR motor basically stock with the exception of the Endyn 81.5mm pistons at 12.3:1 CR and 16 degrees of timing run fine with no detonation on 93 octane.
Endyn designed the RW pistons to make the combustion process more efficient and quicker burning.
I wouldn't go above that 12.3:1 CR on pump gas. You may be able to do this. The person to ask would be Larry Widmer at Endyn. He has probably already done the setup you mentioned. Ask and find out if 12.5:1 CR is possible on pump gas without detonation.
Good luck.
-kenji
Old Jul 1, 2001 | 06:09 PM
slivic's Avatar
Default Re: Can I pull this off? (kenji)
Well that block was sold so now the question is what compression should I order. I am thinking 12:1. What do I order since the head is milled .020.
Josh
Greenery18
32
Apr 21, 2005 07:41 PM
dornon13
16
Jul 19, 2004 04:23 PM
emissionsux
Apr 24, 2003 01:00 PM
UltRaH22
Feb 12, 2003 11:13 PM
B19CivicHB
Mar 22, 2002 08:51 AM
