Best ecu?
Hello guys which out of these ecu's do you reckon would be the best to go for apexi power fc, hondata, or motec.
Re: Best ecu? (Funnyclub)
Go with the ECU that the best tuner near you uses. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Best ecu? (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid »</TD></TR><TR><TD CLASS="quote">Go with the ECU that the best tuner near you uses. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
Probably the best answer you could get... someone tuning an ECU they are very familiar with, IMO, is more likely to get more power for you than someone who is unfamiliar with a different type of standalone. |
Depends what you are trying to achieve as well as the configuration you are trying to achieve it on...
Also as mentioned, select a ECU which local shops are very confortable with, something they have worked with many times before. https://honda-tech.com/forums/images/smilies/emthup.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Funnyclub »</TD></TR><TR><TD CLASS="quote">Hello guys which out of these ecu's do you reckon would be the best to go for apexi power fc, hondata, or motec.</TD></TR></TABLE>
If you can find a Hondata tuner near you, go for it. I suppose you're in Dublin, Ireland, and not one of the seven Dublins in the US? (NH, NC, GA, OH, CA, MS, IN) |
