windshield washer fluid problem!!
I have a problem with my abs light always coming on when I'm driving and staying on. Just yesterday it went away and has not come back on since. Today I tried using my front washer fluid and nothing comes out. These are my items that don't work: rear defrost, seat belt beep, front washer fluid but rear works. As for my abs light blub just blew and cause these other problems.
first, please state which integra you have, it will help a bit.
check the fuses first on those various items. your washer fluid lines or nozzles could be clogged. easy to take apart and clean. the rear defroster switch could be going bad...easy to replace that. the seat belt beep is an issue i'm not sure about, if it doesn't beep, who cares. obviously you have a problem with the abs system, IMO, not worth fixing on a car like this.
as cars get older, these little problems arise. luckily, you can find parts in a junkyard or from the dealer. and replace them yourself.
no problem. the defroster switch is easy to pull out and replace or clean. the washer nozzles pop right off with a screw driver and are easy to clean. the seat belt beep, which is for the automatic seatbelts, is a switch issue. luckily our seatbelts (integras 90-93) are covered under a lifetime warranty. i'm sure you can search here for a thread that has the ntsb link. a dealer should not give you hassle over that. now, if the seatbelt isn't buckled in, then the beeping will continue and you should have it buckled in at all times.
you should seriously consider investing in a helms manual or chilton's manual for the 90-93 integra or 90-93 acura coupes. these books are life-savers on maintaining your car and save alot of money.
also, check out http://www.g2ic.com , it is a great forum/site for gen2 integras. you'll find tons of helpful info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEXNTEG »</TD></TR><TR><TD CLASS="quote">no problem. the defroster switch is easy to pull out and replace or clean. the washer nozzles pop right off with a screw driver and are easy to clean. the seat belt beep, which is for the automatic seatbelts, is a switch issue. luckily our seatbelts (integras 90-93) are covered under a lifetime warranty. i'm sure you can search here for a thread that has the ntsb link. a dealer should not give you hassle over that. now, if the seatbelt isn't buckled in, then the beeping will continue and you should have it buckled in at all times.
also, check out http://www.g2ic.com , it is a great forum/site for gen2 integras. you'll find tons of helpful info.</TD></TR></TABLE>
what he said
TypeR#1049
Jan 27, 2008 03:37 PM
