Window problem
Ok, so I was insalling a 6 1/2 inch JBL speaker in my driver side door, so I took the door panel off, put in the speaker, and plugged all the harnesses back into their spots, and put the door panel on, tested the speaker, it was fine, but then went to roll up my windows, and the drivers side was fine, but the passenger side will not roll up, on either the driver or passenger switch, and yes I checked and it is not the window lock thing. Thanks in advance for any help you can give me.
Are you sure your speakers arent sitting way back in the door? This happened a lot on my old pathfinder. Had speakers with a lot of depth (big magnet) and the windows tended to rub against them every once and a while. Your passanger side window may be rubbing against the speaker enough to make it think its rolled all the way up.
JamesV
Jun 21, 2006 04:07 PM
MikeMAN
Oct 26, 2002 08:45 AM
RATEDR
May 23, 2002 06:39 AM
