Will the Ls exhaust fit on gsr???
Old Mar 16, 2012 | 04:21 AM
b20vteclsintegra's Avatar
Default Will the Ls exhaust fit on gsr???
I know the header will not but will everything else? Someone please let me know asap
Thank you
Old Mar 16, 2012 | 03:11 PM
NemesisCBR's Avatar
Default Re: Will the Ls exhaust fit on gsr???
If your gsr is 00-01 yes. 94-99 used a different length.
Old Mar 17, 2012 | 07:23 AM
jdmgsr98's Avatar
i had a 98 ls and swapped a jdm gsr engine into it and used my same dc sport headers and same invidia exhaust so yes they both will work
Old Mar 17, 2012 | 08:42 AM
sebTeggy's Avatar
Be more specific. Are you swapping motors or swapping headers?
You can swap any b series motor in your car and have the header bolt onto it. Here is where the exhausts are different
2000-20001 GS-R and 1994-2001 LS/ITR are identical, piece by piece (except the second o2 sensor on the rear of the cat for obd2 models)
1994-1999 GS-R axleback is interchangable with 1994-2001 LS/ITR
The 1994-1999 GS-R header is shorter than the 1994-2001 LS/ITR
1994-1999 GS-R cat is the same size as the rest, I believe.....
The 1994-1999 GS-R b-pipe that goes from the cat to the axleback is a few inches longer to compensate for the shorter header. Don't ask me why honda did this. They figured it out in 2000 tho haha.
JDM ITR is a whole different story. Their headers are waay ****ing longer and you gotta customize a lot of ****
xlilninjax
Oct 28, 2010 01:09 PM
jrzy2nR
May 20, 2006 08:17 AM
Droppedatbirth!
Aug 20, 2004 09:20 PM
eg64u
Aug 1, 2004 02:44 PM
OK
Sep 29, 2001 01:55 PM
