Will this header fit?
Old Jan 19, 2005 | 07:50 AM
jsull.'s Avatar
Default Will this header fit?
Will an 2001 Integra GSR DC Sports Header fit on a 1990 Acura Integra LS motor and clear the oil pan?
Old Jan 19, 2005 | 08:02 AM
purplegsr's Avatar
Default Re: Will this header fit? (LSB18A1)
4-1 or 4-2-1?
The 4-1 will probably require you to notch the crossmember so that all of the runners clear it. I haven't heard about many people using the USDM GSR 4-1, it's usually either a JDM 4-1 or they just get a USDM 4-2-1 which should clear fine. I think some people have had problems getting the JDM 4-1 to clear the oil pan, but the USDM has shorter runners supposedly, so it should be fine.
The only other thing is that the lengths of the piping, cat, and header won't match up, so you will need to get some welding done.
Old Jan 19, 2005 | 08:22 AM
NathanMorris's Avatar
Default Re: Will this header fit? (purplegsr (Exospeed))
clearance may be an issue. I'd use a header that was designed for the motor though if I were you.
- Nathan
Old Jan 19, 2005 | 08:33 AM
jsull.'s Avatar
Default Re: Will this header fit? (92Lx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) &raquo;</TD></TR><TR><TD CLASS="quote">4-1 or 4-2-1?
The only other thing is that the lengths of the piping, cat, and header won't match up, so you will need to get some welding done.</TD></TR></TABLE>
yea its a 4-1 one piece I figured I would have to notch the x-member to fit it. Thanks for the help
Old Jan 19, 2005 | 08:36 AM
jsull.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92Lx &raquo;</TD></TR><TR><TD CLASS="quote">clearance may be an issue. I'd use a header that was designed for the motor though if I were you.
- Nathan</TD></TR></TABLE>
Yea clearance will be an issue for sure but I'll manage I figure I'll probably dent in any header. The ones designed for it aren't 4-1 I can only find a 4-2-1 and I really need the top end in my LS. Plus for the price of this DC one I don't think I want to pass it up.
Thanks for your help
IowayRUlz
Apr 19, 2007 05:12 PM
Rhythmsnewsn
Apr 18, 2006 11:00 AM
UNKNOWN_MEMBER
Oct 23, 2004 01:01 PM
.M.
Jul 28, 2004 07:32 AM
typeRSXS
Feb 8, 2004 10:07 PM
