Wierd Idle
Old Oct 2, 2004 | 07:50 PM
de_sxc_b20_teg's Avatar
Default Wierd Idle
My idle is totally f**ked up! On start up rpm's reach 4000. Then it bounces from 1000-3000, in neutral! What can be done? Do I need a TPS or MAP sensor!
Old Oct 2, 2004 | 07:56 PM
flipldls's Avatar
Default Re: Wierd Idle (de_sxc_b20_teg)
well a couple of things that could b the cause of all is a bad distributor, because sounds the same problem i had wit my teg.....if not its either ur wiring to the distributor or spark plugs not firing rite......last could be your throttle body.......peace
Old Oct 3, 2004 | 07:05 AM
Default Re: Wierd Idle (flipldls)
ECU is flashing a 13! Does anyone know where the Atmospheric Pressure Sensor (BARO) is located? Its a 91 Integra with a B20B!
Old Oct 3, 2004 | 11:30 AM
blake2001's Avatar
wow man you need a new distributor or get one from the salvage yard. SAME PROBLEM HERE!!!
Old Oct 3, 2004 | 12:59 PM
Default Re: Wierd Idle (blake2001)
I have the same problem, on an auto version of the car! We did the tune up and still have the same problem! The CEL is on, and like I said, thie ECU is flashing a 13, which is a problem with the BARO sensor! I need to find out where this unit is so I could check it! <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blake2001 &raquo;</TD></TR><TR><TD CLASS="quote">wow man you need a new distributor or get one from the salvage yard. SAME PROBLEM HERE!!! </TD></TR></TABLE> Did the problem go away after you changed yours?
Old Oct 4, 2004 | 04:04 AM
JimBlake's Avatar
On my '95 the baro sensor is built into the ECM. If that's the same you need a new ECM. I think some years the sensor was external, but I don't know which cars/years.
christ0pher
Mar 5, 2009 06:57 PM
e30FTMFW
Sep 26, 2008 10:42 AM
hondastrtracr
Apr 23, 2006 04:25 PM
pornstartom
Dec 13, 2005 02:09 AM
CRX-zila
Jan 29, 2003 08:20 PM
