When checking CEL codes, the check engine light turned off.
Old May 3, 2004 | 04:17 AM
99IntegraGS's Avatar
Default When checking CEL codes, the check engine light turned off. UPDATE
Update: I didn't have the plug jumped properly. Once properly jumped, I'm getting a code 71.... which I think is a random misfire cyl 1.
Is this something to worry about? Should I change plugs?
No series of long and short flashes like I was expecting.
Does this mean that the event or problem that caused the light is no longer present? Did the check engine light just reset when I jumped the pins in the harness?
Thanks,
JD
Modified by 99IntegraGS at 10:27 AM 5/3/2004
Old May 3, 2004 | 07:07 AM
frenchy's Avatar
Default Re: When checking CEL codes, the check engine light turned off. UPDATE (99IntegraGS)
if it happens again its time to start worrying - thanks for knowing how to pull codes and not asking what it was - pull your plugs and make sure theyre not filthy if you want
Old May 3, 2004 | 07:12 AM
SuzukaBlueAP2's Avatar
Code 71 probably isn't anything severe. Check your plug, the wire, the connection on the dizzy, and even make sure the injector is properly connected and secure.
Old May 3, 2004 | 07:18 AM
Thanks for the replies.
Linked
May 16, 2010 11:20 AM
speed_demon018
Mar 12, 2010 06:47 AM
8_UR_AWD
Honda Civic (2001 - 2005)
13
Mar 8, 2009 06:19 PM
JDM-EJ1
Apr 5, 2005 11:55 AM
97gSrkId88
Mar 20, 2003 11:06 PM
