Wheel Spacers
Old Jul 31, 2015 | 04:52 AM
Tom B.'s Avatar
Default Wheel Spacers
I have searched but just found two guys arguing there point and no clear cut answer.
Is it safe to fit 5mm, flat wheel spacers on my '96 JDM ITR wheels?
FYI I ran 5mm spacers on my CRX for several years without any problems.
Thanks in advance for your input.
Old Jul 31, 2015 | 05:29 AM
B_Swapped93's Avatar
Default Re: Wheel Spacers
yes.... but I've always felt unsafe with just the little amount of threads holding had them on my 5lug took them off asap but I was doing into the mid 350 whp wise. if you're just going to drive them normal you're fine with stock studs just don't go over 5.
Old Aug 1, 2015 | 10:02 PM
zchdrl's Avatar
You should be okay with 5mm but to play it safe it's not a bad idea to get extended studs. Also make sure the spacers are the correct center bore or you might get vibrations at higher speeds.
Old Aug 1, 2015 | 10:09 PM
These cars are lug-centric not hub, just saying even H&R spacers will be a bigger bore. I just don't like the idea of spacers past 60 mph always felt ****.
jdmspoonitr
26
Nov 4, 2015 01:15 PM
TheMuffinMan
Aug 29, 2009 09:59 AM
gringo7718
Suspension & Brakes
Aug 12, 2009 08:27 PM
josh's ep3
17
Jan 28, 2009 11:07 AM
