whats the difference between the 94-97 integra from the 98-01 ?
all I know are the front bumpers and wheels are different is there anything else that make the 98-01 different? I've heard the rear bumpers are different too but I can't tell the difference.
Re: whats the difference between the 94-97 integra from the 98-01 ? (scobaru)
The front bumper, headlight assembly, front corner lights, rear bumper, tailights. Everything on the 98-01 will bolt onto the 94-97, as long as you use correct headlights for the front bumper.
Front and rear bumpers, headlights, and tail lights, turn signal lamps, wheels, minor chassis reinforcement (to meet stricter safety standards), and color options.
http://demonwyld.com/temp/teg_0205.jpg
Older pic of my GSR. It's a 2000. Notice the more flush front headlights and different front bumper when you compare it to a 94-97. I've got the Type r lip on it in that photo. |
Re: (RuskeR)
Can you post a comparison pic of the differences
Re: (RuskeR)
98+ gsr has adjustable seat height
98+ looks better 94-97 steering wheel says "Acura", 98-01 steering wheel has the "A" symbol 98-01 have a just a fuel lever, no hatch lever Styling lines were added to the side mirrors in 96. Pre-96 Integras had smooth mirrors Side door moldings were color-matched to car’s body color in 97 for LS models and in 95 for SE models ODB II Introduced in 1996 Keys have computer chip built-in in 2000 Exhaust system changed in 2000 96 up valve cover on LS is flat across over the cam section, 94-95 cover has raised parts over the cam section. |
Re: (143MYVTECEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 143MYVTECEF »</TD></TR><TR><TD CLASS="quote">Can you post a comparison pic of the differences </TD></TR></TABLE>
go here http://www.team-integra.net/se...D=480 |
Re: (teggsr925)
Differences
# 98-01 front bumper is more aggressive looking # 98-01 rear bumper has air dam # Headlights are different size # Bumper lights are different size # 98-01 taillights are all red, 94-97 has amber turn signals # 94-97 steering wheel says "Acura", 98-01 steering wheel has the "A" symbol # 98-01 have a just a fuel lever, no hatch lever Now for the questions people always ask: The 98-01 front bumper WILL fit on the 94-97 models ONLY if you also change: # Headlights and bumper lights # Same with headlights, must change the front bumper to work # 98-01 bumper lights will NOT fit on the 94-97 bumper and vice-versa # 98-01 tailights WILL fit on 94-97 models and vice-versa # 98-01 rear bumper WILL fit on 94-97 models and vice-versa Here are some other differences found on Gen. 3 Integras that were not exclusive in the 94-97 to 98-01 changes, feel free to [ contact me ] to add to the list: # Styling lines were added to the side mirrors in 96. Pre-96 Integras had smooth mirrors # Side door moldings were color-matched to car’s body color in 97 for LS models and in 95 for SE models # ODB II Introduced in 1996 # Keys have computer chip built-in in 2000 # Exhaust system changed in 2000 # 96 up valve cover on LS is flat across over the cam section, 94-95 cover has raised parts over the cam section. Team-Integra's info! https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (teggsr925)
[QUOTE=iH8RICERZ;26727802]Differences # 98-01 front bumper is more aggressive looking # 98-01 rear bumper has air dam # Headlights are different size # Bumper lights are different size # 98-01 taillights are all red, 94-97 has amber turn signals # 94-97 steering wheel says "Acura", 98-01 steering wheel has the "A" symbol # 98-01 have a just a fuel lever, no hatch lever Now for the questions people always ask: The 98-01 front bumper WILL fit on the 94-97 models ONLY if you also change: # Headlights and bumper lights # Same with headlights, must change the front bumper to work # 98-01 bumper lights will NOT fit on the 94-97 bumper and vice-versa # 98-01 tailights WILL fit on 94-97 models and vice-versa # 98-01 rear bumper WILL fit on 94-97 models and vice-versa Here are some other differences found on Gen. 3 Integras that were not exclusive in the 94-97 to 98-01 changes, feel free to [ contact me ] to add to the list: # Styling lines were added to the side mirrors in 96. Pre-96 Integras had smooth mirrors # Side door moldings were color-matched to car’s body color in 97 for LS models and in 95 for SE models # ODB II Introduced in 1996 # Keys have computer chip built-in in 2000 # Exhaust system changed in 2000 # 96 up valve cover on LS is flat across over the cam section, 94-95 cover has raised parts over the cam section. Do 96 front signal lights fit 99?? |
Does it look anything like post #$
Does anyone know if the side interior pieces that go from behind the driver and passenger seat, all around the hatch from a 97 will fit on a 98?
Originally Posted by dc4shaq
(Post 52013617)
Here's some more info.
94-95: OBD1 96-99: OBD2A 00-01: OBD2B |
