What mod next????
Old Feb 27, 2005 | 11:16 AM
DarKStaR5's Avatar
Default What mod next????
Ok i have a LS with i/h/e, i was wondering what should be the next mod to do that will give me the most for the money. I do not want to go turbo. thanks
Old Feb 27, 2005 | 11:25 AM
NeoGSR's Avatar
Default Re: What mod next???? (DarKStaR5)
apexi afc?
a dyno tune with that should give you something i would think
Old Feb 27, 2005 | 11:37 AM
brickonwheels's Avatar
vtec head?
Old Feb 27, 2005 | 12:07 PM
Tommy1223's Avatar
suspension? it'll give more power to the wheels and traction will be better too.
Old Feb 27, 2005 | 12:36 PM
Ethereal's Avatar
Default Re: (AzN_Dc2GS)
i'd go with suspension, some springs,shocks,swaybars will really make your cars cornering abilities improve.
Old Feb 27, 2005 | 12:47 PM
teknoracing's Avatar
Default Re: (Ethereal)
An NO2 kit
Old Feb 27, 2005 | 01:14 PM
GSRerrr's Avatar
Default Re: (teknoracing)
uhmm... TEST PIPE for 60$$ works really well if u dont hafta pass smog
Old Feb 27, 2005 | 01:26 PM
.special ed.'s Avatar
koni shocks, gc sleeves, and itr rear sway bar.
Old Feb 27, 2005 | 01:40 PM
b18vtek's Avatar
How bout sum pistons or cams?? Those should give power. Change your tranny to a SI tranny. Some weight reduction. Ummm.......... take out you A/C P/S and ABS and what everybody else said.
Old Feb 27, 2005 | 01:51 PM
Ketone's Avatar
Default Re: What mod next???? (b18vtek)
The best modification you can do is to get a itr tranny. You will love it!
Old Feb 27, 2005 | 02:05 PM
LSvtec03's Avatar
Default Re: What mod next???? (Ketone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ketone &raquo;</TD></TR><TR><TD CLASS="quote">The best modification you can do is to get a itr tranny. You will love it!</TD></TR></TABLE>
also do some suspension and an itr sway bar.
Old Feb 27, 2005 | 02:39 PM
G-bonic's Avatar
Hijacked
b16 tranny, itr sway bar, gud springs or coilover and shocks, and 2.5 piping all the way..... oh yeah and stripped interior..
Old Feb 27, 2005 | 04:06 PM
escape2me's Avatar
Default Re: What mod next???? (Stock_LS)
intake manifold
Old Feb 27, 2005 | 04:43 PM
dohcMONSTER's Avatar
Default Re: What mod next???? (97 GSR)
intake manifold, crower all motor cams, build the head, different tranny........lose weight?
Old Feb 27, 2005 | 05:04 PM
migs's Avatar
Default Re: What mod next???? (sohcMONSTER)
CTR/USDM ITR tranny.
Dont waste your time on the other stuff. The tranmission will be the best bang for the buck.
Old Feb 27, 2005 | 05:11 PM
Spoon ITR's Avatar
Default Re: What mod next???? (migs)
headwork, cams, full valvetrain, manifold, afc, dyno it
Old Feb 27, 2005 | 05:21 PM
honda011's Avatar
Default Re: What mod next???? (JDMDC2GSR)
intake manifold, or some nitrous...
Old Feb 27, 2005 | 05:37 PM
EFMAN's Avatar
intake manifold,plug/plug wires,unorthodox pullies,nos,suspension
Old Feb 28, 2005 | 09:41 PM
LSvtec03's Avatar
Default Re: What mod next???? (EFMAN)
he's not ready for an intake mani without upgrading the head first (cams at least).
plus 2.5" piping is a little extreme for a stock LS. probably better off with 2.25 or 2.36 (60mm).
Old Feb 28, 2005 | 09:43 PM
MaskedAP1's Avatar
Default Re: What mod next???? (LSvtec03)
cam
Old Feb 28, 2005 | 10:10 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: What mod next???? (MaskedDC4)
Look if your looking to go fast, you really dont need to worry about alot of suspension work, just get some coilovers sometime. But to go fast in an LS get a B16 Trans, its the cheapest and you can pick one up for cheap. thatll put you into the low 15's. Next get some Crowers Stage three cams/ valvetrain and some head work. do some research, thats a mean set up just off of those three things alone.
Old Mar 1, 2005 | 12:29 AM
lsvtecteggie's Avatar
N20 all the way, vtec head
Old Mar 1, 2005 | 12:37 AM
Haleiwa-Brando's Avatar
frontal lobotomy?
Old Mar 1, 2005 | 03:17 AM
bee18see1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFMAN &raquo;</TD></TR><TR><TD CLASS="quote">intake manifold,plug/plug wires,unorthodox pullies,nos,suspension </TD></TR></TABLE>
Plugs/ plug wires aren't going to gain you anything. Pulleys are still IMO a waste of money for the very small (if any) difference you might see on a dyno. Manifold, as LSvtec03 stated, won't do much good on a stock motor anyways, and nitrous, well you may just want to be careful about that. Stick with a good suspension, you'll be happier with that instead of a single part that won't see a lot of gains.
Old Mar 1, 2005 | 03:43 AM
Team Underground Teg's Avatar
I would do suspension, stripped interior, remove A/C, P/S, ABS, and do some cams and ignition with some dyno tuning. That should help.
