what to do with my block
Old Aug 6, 2004 | 11:39 PM
ctegsta's Avatar
Default what to do with my block
my stock ls over heated due to a leak in my radiator that i did not notice, well i replaced the radiator but it seems like im loosing compression, well actually i am loosing compression, should i replace my piston rings or would i be better of replacing the block, wich is more costly and wich is more dependable, im thinking about buying a new block
thanks for the help in advance
Old Aug 7, 2004 | 10:43 AM
SIK IN DA HED's Avatar
New User
if your block overheated, you might want to make sure you didnt warp the head. if everything is fine but youre losing compression, it really all depends on how much compression your losing and the inconsistency of the test.
Old Aug 7, 2004 | 11:37 AM
tegmech's Avatar
what are the compression #'s?
Old Aug 8, 2004 | 11:04 PM
ctegsta's Avatar
i did not do a compression test, my car is just not responding as fast when i press the gas, it gets hesitant, but when im on fifth and on the freeway it drives smooth
Sport_Injected
Nov 11, 2004 07:43 PM
Chillinit
Jul 23, 2004 03:22 AM
lke2drvgsr
17
Jan 17, 2004 12:44 PM
YOSOLO CRX
13
Nov 13, 2003 08:53 PM
