what is the difference....
ight i want to know what make the big difference between the type R teg and the gsr??? if i were to use a type r block and a gsr head would it produce better hp or performance or vice-versa?? holla bak thanks
First motor
-Better cams
-stiffer valve springs
-port and polish from the factory
-bigger manifold, not dual buttrfly
-bigger intake mani
-Higher compression ratio 10.6:1
Tranny
-closer gears
-lsd
-better chasis and suspension
-diff sway bar up front
-no moon roof
-higher oil pressure
-higher fuel pressure
-or cruise control
-suede interior
-5 lug
-carbon fiber dash
-diff spioler
-higher redline
-titnauim shift ****
-no side moldings
-front lip and skirts are painted
hope this helps cant really think of anyhting else
-Better cams
-bigger intake mani
Tranny
-closer gears
-lsd
-no moon roof
-or cruise control
-suede interior
-5 lug
-carbon fiber dash
-diff spioler
-higher redline
-no side moldings
...i want to know what make the big difference between the type R teg and the gsr?
The ITR has a stiffer chasis, tighter/tuned suspension, better handling, better weight distribution, better brakes, better ABS, higher output engine, better gear ratio's in the tranny, LSD, slightly lower ride height, and is simply a no-frills race car in disguise... there's more but I don't feel like typing it all out.
Ask this same question in the ITR forum. Your likely to get a better response.
[Modified by Ralphie, 1:46 AM 12/7/2002]
bsmith100
Aug 18, 2009 08:41 AM
