what causes this?
Old Nov 13, 2010 | 04:28 PM
accord2civic2prelude's Avatar
Default what causes this?
when i connect the negative battery terminal, the fuel pump primes and the gauge cluster comes on as if the key was in.
Old Nov 13, 2010 | 05:30 PM
4stagecandy's Avatar
Default Re: what causes this?
one thread will do , check the ignition wires
Old Nov 13, 2010 | 06:51 PM
yea sorry bout that. figure id get more help i guess. but i have my ignition swiched through a couple of relays. ill go run through the wires and find out.
Old Nov 14, 2010 | 01:11 AM
i check all fuses, unplugged the ignition switch harness(both) from under steering column. i unplugged all 3 shock tower plugs. funny thing is, when all 3 are unplugged, the gauge cluster(brake and check engine) lights are still on. when i plug in the 2nd largest, the fuel pump primes. what else should i check?
Old Nov 14, 2010 | 08:01 AM
fcm's Avatar
fcm
Old Fart
What do you mean, "but i have my ignition swiched through a couple of relays" what leads are the relays on and why? 94
Old Nov 14, 2010 | 08:28 AM
94rs-turbo's Avatar
Old Nov 14, 2010 | 11:34 AM
i had the relays connected to the ignition swtich. basically one switch to turn car on and a push start. it has been on for about 2 years now. only when i was messing with the external coil, i noticed the problem. so i disconnected all wires from both switch and push button. it was done by an electricion, not me.
the reason being, is that A LOT of civics are stolen here in hawaii..and suprisingly, someone tried to still mine but couldnt figure how to start.
Old Nov 14, 2010 | 04:26 PM
fcm's Avatar
fcm
Old Fart
OIC a relay on the ign. lead and one on the starter lead, it sounds like the relay on the ign. lead is "seized" closed, supplyinf 12V+ constant to the cars ign. system, or part of it.
Remove the relay and reconnect the cut ign. lead, [if it was cut and not a parallel connection]. 94
Old Nov 14, 2010 | 05:30 PM
ok. the ign relay is the one in the under hood fuse box right?
if so, i changed that with another relay and it worked. but now, my hazard button is acting as the acc/on buton for some reason.
Old Nov 14, 2010 | 06:05 PM
ok..got the ignition figured out. everything with that is ok. the problem now, is that when i turn the key to start, nothing happens. lights doesnt dim or anything.
Old Nov 15, 2010 | 05:18 AM
fcm's Avatar
fcm
Old Fart
Remove the relay on the starter lead and reconnect the cut starter lead. 94
Old Nov 15, 2010 | 09:50 AM
confused!! where is the relay on the starter lead and i never cut any wire.
Old Nov 15, 2010 | 11:09 AM
fcm's Avatar
fcm
Old Fart
You said...
"but i have my ignition swiched through a couple of relays" and...
"i had the relays connected to the ignition swtich. basically one switch to turn car on and a push start.
So where on the "ignition switch" did you put the two relays, or am I misunderstanding "a couple of relays"???
Also, MM&Y of car and is it an auto or manual transmission? 94
Brittain
Jan 7, 2016 05:51 PM
thecruzs2007@yahoo.com
Mar 8, 2011 09:44 AM
Nov 14, 2010 01:46 PM
BlkB16EK9
Mar 27, 2006 07:21 PM
