werid problem with idle and starting
Subscribe
May 19, 2006 | 03:43 PM
ight well i just replaced the spark plugs and the start. i go and start it up and it starts just fine. i then let it idle but when i hit the brake the idle jumps 500 rpms, how come its doing that? k then i turned off the car and tried to start it back up and it didnt work and is no longer working. anyone have any ideas?
Reply 0
May 19, 2006 | 09:05 PM
Re: werid problem with idle and starting (skata89)
was it doing this prior to you working on it
Reply 0
May 20, 2006 | 04:10 AM
ya it did it once or twice before it and after it, it just went down hill from there.
Reply 0
May 20, 2006 | 02:24 PM
Re: (skata89)
The RPMs will change because the brake booster uses vacuum and generally causes the engine to idle up a bit. Check your distributor connections. What mods are done to the car what mods do you have/what else have you been ******* with?
Reply 0
May 21, 2006 | 05:58 AM
I only have i/h/e. and all ive really done is changed the clutch but my problem was happening before that tho.
Reply 0
May 21, 2006 | 06:06 AM
Re: (skata89)
check the Idle air control and clean it out. or it could be something to do with the throttle positioning sensor.
Reply 0
May 21, 2006 | 06:23 AM
how do you clean out the idle air control
Reply 0
Subscribe
