weird rattle....
Old Oct 19, 2005 | 02:22 PM
bigmikerich20's Avatar
Default weird rattle....
hi when i have it beween like 1500 and 3000 rpm's it rattles.. people told me it was a heat shield. If you have any opinions on what i can do to get it to stop plz let me know.
Old Oct 19, 2005 | 02:38 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: weird rattle.... (bigmikerich20)
It could be a heat sheild, or it could be a rattling on the inside of the header/B-pipe. There is another layer of "tubing" that sometimes starts rattling.
It's a very common problem among Integras. The heat sheild, if that's the culprit, is the one above or below the catalytic converter. You can just remove that if you like.
Old Oct 19, 2005 | 03:28 PM
4dr_all_day's Avatar
sounds like a heat shield... if it is just take it off
Old Oct 20, 2005 | 03:28 PM
Default Re: weird rattle.... (shamoo)
thanks i was plannin on it.. but i heard it can heat up and melt thru stuff. i dono if this is true but a buddy of mine says it is?? but thanks for the info so far
Old Oct 20, 2005 | 03:38 PM
shamoo's Avatar
The upper catalytic heat shield shields heat from the exhaust going toward the shifter area. If you remove the upper shield (most people leave the upper, and just remove the lower), you'll feel slightly more heat in the shifter area.
The lower shield just shields heat from the exhaust going toward the ground. There is a slight possibility that parking over dry leaves/grass might set it ablaze. Not likely, but possible.
Old Oct 20, 2005 | 04:29 PM
k thank you.. ok another question of mine was that i was going to put a 98 ITR motor swap in my 96 integra... would that be better than just buying a civic hb and putting an h22A in it?? jw because i am stuck between the two.. your input wouldreally help
Cody's Si
Aug 5, 2006 10:48 AM
IRnIntoPrkedCars
Aug 19, 2005 09:38 AM
KrisAcura
Oct 1, 2004 11:11 PM
Spade
23
Jul 30, 2002 04:27 PM
slimbo
Mar 24, 2002 11:36 AM
