weird noise when accelerating !!!
Could you be more specific? "Getting on your car when it's still cold" Hmm....that doesn't sound different to me.
High pitched? Low pitched? Dependent on wheel speed? Dependent on engine speed? Does it all the time?
..high pitched.. (its hard to describe a noise)... kinda like a hissing noise of some sort.. depending on the engine rpm.. usually around 4-5, car def. feels more sluggish..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackThorN »</TD></TR><TR><TD CLASS="quote">exhuast leak?
Ground loop in your stereo system?
Intake Leak?
Bearing gone bad?</TD></TR></TABLE>
it might be that, cuz when i installed my amp's, it made that noise, but it was through the speakers.. kinda hard to notice where it was actually comming from, but i found out it was the speakers.
what about altanator? i know thats a shot in the dark, but i think i remember hearing someone talk about this in past thread's
Intake Leak?
It's probably an exhaust leak. Mine would make a real whiney noise (more noticeable while cold) up thru the RPM range. Found the leak and welded it shut. No more clangy whiney noise
na not the stereo, im positive about that... damn i hope its not a bearing... that would suck...it really sounds like if u beat on ur car when its cold... or is it just my car that sounds diff. cold?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. »</TD></TR><TR><TD CLASS="quote">
how do u fix the ground loop problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Does the noise occur if you just rev? I'm thinking engine accessery.</TD></TR></TABLE>
engine accessery as in ....?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1hotintegra »</TD></TR><TR><TD CLASS="quote">
engine accessery as in ....?</TD></TR></TABLE>
PS pump, AC compressor, water pump, alternator
You said that there was a power loss associated with this noise. One of those components may have a worn bearing. Does the engine still rev freely?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warric_k »</TD></TR><TR><TD CLASS="quote">when exactly does it happen? during/right after a shift? does the whining change pitch?</TD></TR></TABLE>
it happens all the time around 4-5k no matter if im shifting or not... def. def. def. not stereo.. i've had that that before and its not that...im clueless.. i hate this sh*t. anyway any more insight is def def a big help thanks
changed plugs, checked ign. timing and did compression test today.... timign was a lil off but set to stock... compresstion test was about 230 accross the board.. is that a little high??
its the clutch belt... happens all the time. here is a link to get a new one:
http://www.kalecoauto.com/general.htm
-Mythias
-Mythias
