vtec light
Making an vtec light is very easy. Just look on your under the hood fuse box panel. Under that panel tells you where everything is located. One on there should say vtec solenoid. Hook a light bulb or led up to that run that exact wire into your fire wall and then connect to a spot on the dash. Then when the vtec kicks in the led of light bulb will glow. If it does not glow then you could have something wrong with your vtec soleniod.
