valve specs?
I use the .006" blade on my feeler guage for the intake and .007" for the exhaust. I adjust the intake so the .006 fits and the .007 does not, and the exhaust so that the .007 fits and the .008 does not.
If you're using the Sk2 cams, the directions I've read on the Stage 1's, says to go on the looser end of the factory specs.
Intake: .15mm - .19mm
Exhaust: .17mm - .21mm
When I clearanced a pair of Stage 1's, they were initially done using the .178mm and .203mm feeler blades, and double-checked against the next bigger size...as you should always do.
wagon-r
Jun 11, 2013 09:32 AM
ArchAngel Sabastian
Oct 13, 2003 06:59 PM
