vacum problem on b18c.. please help.. pics of engine inside
Old Apr 28, 2005 | 03:23 PM
DrazoYU's Avatar
Default vacum problem on b18c.. please help.. pics of engine inside
engine is fine in idle, as soon as i rev it up, it chokes and it goes dead
i'm getting these 2 CELs
- P0106 Manifold Absolute Pressure (MAP) Sensor Range/Performance Problem
- P1259 VTEC System Malfunction
here is the image of the manifold it that can help..
thx in advance
Old Apr 28, 2005 | 03:27 PM
SuzukaBlueAP2's Avatar
Default Re: vacum problem on b18c.. please help.. pics of engine inside (DrazoYU)
what's that Denso sensor that's just hanging out on top of the Intake Mani?
Old Apr 28, 2005 | 03:28 PM
DrazoYU's Avatar
Default Re: vacum problem on b18c.. please help.. pics of engine inside (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">what's that Denso sensor that's just hanging out on top of the Intake Mani?</TD></TR></TABLE>
i'm not sure, it used to be on my b18c1 engine just bolted on the top of mani
Old Apr 28, 2005 | 03:31 PM
I'd have to say that would be part of the problem, since it has 2 ports on it that nothing is attached to. it's just a matter of figuring out what it is.
Might have to look at a parts diagram online.
Old Apr 28, 2005 | 03:35 PM
DrazoYU's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">I'd have to say that would be part of the problem, since it has 2 ports on it that nothing is attached to. it's just a matter of figuring out what it is.
Might have to look at a parts diagram online.</TD></TR></TABLE>
that hose from throttle body goes to one of those inputs on that sensor.. but i cant figure out where does the other one go.. seems like 18c engine doesnt have one of these.. so would it be worth replacing my manifold wiht my old one from 18c1?
Old Apr 28, 2005 | 03:45 PM
DrazoYU's Avatar
does anyone have vaccum diagram for b18c? thanks
Old Apr 28, 2005 | 11:40 PM
DrazoYU's Avatar
any input? please guys i need my car to work..
Old Apr 29, 2005 | 04:55 AM
Honteggie's Avatar
The map sensor is the one on top of your throttle body. It could be bad. Also make sure you don't have the tps and map sensor plugs switched as I hear this is a common mistake.
Old Apr 29, 2005 | 05:15 AM
Honda Hick's Avatar
Default Re: (wanahonda)
This is the vacuum diagram for a '94-'95 B18C1. Definately get those hoses hooked up correctly and all the sensors. The vacuum diagram should also be underneath your hood if the B18C was in your car originally.
Old Apr 29, 2005 | 06:20 AM
DANG YO's Avatar
Default Re: (Honda Hick)
that vaccum line u outlined in RED isnt suppose to be there. that piece of tube on have sitting on ur valve cover is suppose to go from the denso sensor on top of ur intake manifold (the sensor with 2 ports that arent hooked up) to that vaccum spot on ur manifold where u have that vaccum line that goes no where. also there should be another line coming off the same sensor into the (black can) on ur firewall
Old Apr 29, 2005 | 05:35 PM
DrazoYU's Avatar
Default Re: (dc2kid)
thanx for the help and diagram studs.. i appriciate that alot..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2kid &raquo;</TD></TR><TR><TD CLASS="quote">that vaccum line u outlined in RED isnt suppose to be there. that piece of tube on have sitting on ur valve cover is suppose to go from the denso sensor on top of ur intake manifold (the sensor with 2 ports that arent hooked up) to that vaccum spot on ur manifold where u have that vaccum line that goes no where. also there should be another line coming off the same sensor into the (black can) on ur firewall</TD></TR></TABLE>
--- that hose thats on my valve cover is to big to fit the TB.. its way smaller then the size of that hose.. should i swap my TB back from b18c1 that's bigger?
thanx
Modified by DrazoYU at 9:09 PM 4/29/2005
speedfreak44
Jun 6, 2014 02:34 PM
thangnhocngheo
Jun 30, 2010 07:39 PM
mesonerz
May 21, 2008 01:11 PM
integraLB1S
Apr 17, 2007 09:34 PM
oxSLEEPERxo
22
Jul 21, 2005 02:47 PM
