V1 Concealed Display Install
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
A big step toward privacy .
Tired of other drivers crowding up behind so they can live off your detector warnings? Or maybe you just prefer to keep a low profile. Here's a remote display that partners with V1, moving all the visual warnings to a location of your choosing while V1 continues on duty in the dark mode.
The Concealed Display may be attached directly to the Lighter Adapter (see Note below). Or you may mount it anywhere using self-stick interlocking fasteners, then connect with the power cord (included) to either the Lighter Adapter or Direct-Wire Power Adapter (both included with V1).
Mute and Mode selection are controlled by the Control **** on the Display (On-Off and Volume adjustments remain on V1).
This compact module measures only 1.0-in. H x 2.5-in. W x 1.2-in. D. Satin-black finish matches V1.
Note: This "attachment" is not possible with the old single-wire Lighter Adapter used up through 1997. Replace with post-1997 Adapter (Item 20314) as used on today's V1.
Includes: Concealed-display module; Power cord, 8-ft.; Power cord, 3-in.; Display-module backplate (for mounting); self-stick interlocking fasteners.
http://www.valentine1.com/moreinfo/PriceList.asp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike5809 »</TD></TR><TR><TD CLASS="quote">Very nice, how much did you pay for the V1?
How is it powered, cig lighter? any other pics</TD></TR></TABLE>
$350 shipped for the V1 and the concealed display. The V1 is hardwired.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura »</TD></TR><TR><TD CLASS="quote">any how to?</TD></TR></TABLE>
Open up your clock, open up the concealed display, and then be creative
But won't the V1 have any obstructions in obtaining the correct signals. IIRC don't they need a clear view/path for the most accurate information. And even having tinted windows have an affect towards their use. Someone correct me if I'm wrong. But I was planning on purchasing a V1 myself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flood_ »</TD></TR><TR><TD CLASS="quote">$350 shipped for the V1 and the concealed display. The V1 is hardwired.
Where exactly did you get it for this price?
</TD></TR></TABLE>Where exactly did you get it for this price?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Championship »</TD></TR><TR><TD CLASS="quote">
Thought so, with that being said, the location of the V1 is ingenious imo, but blows, since you'll most likely experience some questionable results due to the way it is positioned.
</TD></TR></TABLE>Thought so, with that being said, the location of the V1 is ingenious imo, but blows, since you'll most likely experience some questionable results due to the way it is positioned.
