used autometer tech~RPM's is off??
Old Jun 20, 2003 | 05:45 AM
grlstockb18c1's Avatar
Default used autometer tech~RPM's is off??
someone gave me a used tach( which it was already off ) and just got my autometer memory tachometer installed the other night... when its at idle its only 500 RPM's off ( i.e. my tach in the car will read 1,000 and the autometer tach reads 1,500) then when i drive, it seems that the faster i go the more the tach is off? (i.e. car tach reading 4,000 RPM and the autometer reading 6,500 RPM) is this a problem that can be fixed or is it just broken? thanks
girliegrlgsr4life
Old Jun 20, 2003 | 05:47 AM
Sorry its supposed to say TACH not TECH
Old Jun 20, 2003 | 06:32 AM
Tweakmeister's Avatar
Default Re: (girliegrlb18c1)
is there an adjustment **** on it?
does it require a ground?
is the connection soldered?
try those.
Old Jun 20, 2003 | 06:54 AM
no theres not ajustment **** on it, well what i can see. yah theres a ground wire
Old Jun 20, 2003 | 07:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: used autometer tech~RPM's is off?? (girliegrlb18c1)
The AutoMeter is reading about 1.5 times faster than the car's tach. I'm betting that the 2 wire loops inside the tach that make it set for an I4 engine were not cut like they were supposed to be. I bet the AutoMeter tach thinks it's reading a V6 or something.
Best bet would be to hook up a test tach (an auto store or auto shop might be able to do it) or hook up another aftermarket tach and see which one is reading correctly and which one is off.
Old Jun 20, 2003 | 09:11 AM
Default Re: used autometer tech~RPM's is off?? (PatrickGSR94)
yah thats what some people were saying that it might be for a 6 cylinder car~its not reading a 4 cylinder
monkeydude3602000
Jul 20, 2008 01:11 PM
Dropped90Integra
Feb 1, 2005 07:21 AM
Beezle
Nov 2, 2004 10:33 AM
mitsuman
Apr 20, 2004 10:07 PM
94hondaLS
Jun 23, 2003 10:28 PM
