upper ball joint question.
Old Feb 22, 2007 | 08:24 AM
b20acura's Avatar
Default upper ball joint question.
well yesterday i was replacing my axle, and didn't know i didnt have to take off the upper ball joint. now i cant really tighten it. when i try to tighten the castle nut, the whole thing spins, whole thing as in the upper ball joint's stud and the castle nut.
has anything had this problem? how is this solved?
and yes i searched. Your search for upper ball joint returned 6 results.
Modified by b20acura at 9:50 AM 2/22/2007
Old Feb 22, 2007 | 08:32 AM
DraginTeg93's Avatar
Default Re: upper ball joint question. (b20acura)
Should of lubed the nut before you put it back on than it wouldnt get stuck and you could turn it on by hand and then just tighten it up .. Try to use a fork
Old Feb 22, 2007 | 08:52 AM
b20acura's Avatar
Default Re: upper ball joint question. (DraginTeg93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DraginTeg93 &raquo;</TD></TR><TR><TD CLASS="quote">Should of lubed the nut before you put it back on than it wouldnt get stuck and you could turn it on by hand and then just tighten it up .. Try to use a fork </TD></TR></TABLE>
hmm still confused. the problem is that it wont tighten up cuz the castle nut and the stud is turning at the same time.
Old Feb 22, 2007 | 09:03 AM
Saying if you would of lubed the nut up than it would get stuck and the balljoint wouldnt spin with the nut .. trying useing a fork and and see if it tightens it up and see if you can get the nut tighter
Old Feb 22, 2007 | 09:07 AM
mcclungd2000's Avatar
you need a small pair of vise grips. pull up the boot until you can clamp it on.
Old Feb 22, 2007 | 11:41 AM
GserpleaSR's Avatar
Put the jack under the lower ball joint and raise it, then use an air gun on the upper ball joint!!
Old Feb 22, 2007 | 01:49 PM
b20acura's Avatar
Default Re: upper ball joint question. (GserpleaSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GserpleaSR &raquo;</TD></TR><TR><TD CLASS="quote">Put the jack under the lower ball joint and raise it, then use an air gun on the upper ball joint!! </TD></TR></TABLE>
haha if i had an airgun i would
Old Feb 22, 2007 | 03:24 PM
mc-integra111's Avatar
I have seen ball joints with a small slot machined into the end of the threaded portion (looks like from a cutoff wheel and a dremel?). This enables you to stop it from rotating with a screwdriver while tightening the nut. Once the nut is kinda tight, you won't need the screwdriver anymore because the taper on the ball joint will likely hold it steady.
Old Feb 22, 2007 | 04:12 PM
IN VTEC's Avatar
Tap the castle nut to clean the threads, install the balljoint into the knuckle, lightly thread the castle nut onto the balljoint, jack up the LCA (with strut assy installed) to put tension into the suspension, tighten castle nut with wrench, and install the cotter pin.
Old Feb 22, 2007 | 11:51 PM
b20acura's Avatar
Default Re: upper ball joint question. (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Tap the castle nut to clean the threads, install the balljoint into the knuckle, lightly thread the castle nut onto the balljoint, jack up the LCA (with strut assy installed) to put tension into the suspension, tighten castle nut with wrench, and install the cotter pin.</TD></TR></TABLE>
thnx will try tmr
Niskyspy
Jun 30, 2008 06:29 PM
sky9
12
Jan 8, 2008 01:39 PM
azian21485
May 2, 2005 05:48 PM
pikappaphi
14
Feb 6, 2004 09:15 AM
robbin
Feb 24, 2003 10:16 AM
