turbo help!
Old May 10, 2004 | 03:56 PM
ff9zidane's Avatar
Default turbo help!
ok, hopefuly the post wont get blocked, dunno y the last one did. ok i have a 200 integra GSR, bone stock and im savin money from my summer job to get a stage 2 turbo. I was hoping to get some input on what make of turbo i should get, and y. i was also wanting some info on building up my engine to take more boost with out goin boom. so if anyone could help me that would be great. thanks,
Old May 10, 2004 | 04:46 PM
dc2_teggy's Avatar
Default Re: turbo help! (ff9zidane)
hey if u need some turbo help u should go to team-integra.net and read up on the turbo 101 manual! also when looking for a turbo see if there is any shaft play. also there are different types of turbo's u might want to look at. ball bearing, oil... also u may want to consider building a better bottom end. sleeve the engine...etc. on the turbo kit side.... the kit pretty much has everything u need to bolt on the turbo hence "bolt on turbo kit" but also u want to consider how much boost u want to run. i've heard on some stock internals u can run 7psi fine... well good luck and hopefully u can find a trubo or turbo kit later
Old May 10, 2004 | 04:50 PM
silver00teg's Avatar
Default Re: turbo help! (dc2_teggy)
ask in the forced induction forum
Old May 10, 2004 | 04:53 PM
Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ff9zidane &raquo;</TD></TR><TR><TD CLASS="quote">ok, hopefuly the post wont get blocked, dunno y the last one did. </TD></TR></TABLE>
Are you kidding me?
How the hell can you come to a MESSAGE board and not know how to read, I spelled it out for you.
POST IN THE FORCED INDUCTION FORUM.
stknfghtr1
Aug 3, 2011 10:52 PM
stknfghtr1
Aug 3, 2011 06:21 PM
allmotrwagn
Feb 18, 2007 10:40 PM
