turbo auto
Old Mar 6, 2003 | 05:55 PM
LStech's Avatar
Default turbo auto
does ne one in this forum have a turbo charged teg that's an auto? if so did you upgrade the tranny? thanx.
Old Mar 6, 2003 | 08:07 PM
Loveless's Avatar
Default Re: turbo auto (LStech)
you'll most likely blow your auto tranny if you try to go turbo setup with it
Old Mar 6, 2003 | 08:13 PM
rubens's Avatar
shadowdawn does. 98% of the people on here would highly reccomend against it..as would I.
Old Mar 6, 2003 | 10:26 PM
Sukebei Oni's Avatar
with a turbo auto, do you still hear the BOV when the car shifts?
Old Mar 6, 2003 | 10:32 PM
Type Wah's Avatar
Default Re: turbo auto (Sukebei Oni)
Shadowdawn is my hero.. He's had an auto turbo LS for a while now.. it hasn't blown up yet, what a soldier!
[Modified by Type Wah, 7:32 AM 3/7/2003]
Old Mar 6, 2003 | 10:38 PM
MikeyDB7's Avatar
a lotta people in the show scene have turbo auto integs.. example.. a recent issue of import tuner featured a candy red integ LS auto turbo... if you follow the show scene.. Team hybrid's silver integra ls is another turbo auto.. i think thats pretty unique... might not be the fastest.. but its diffrent
Old Mar 6, 2003 | 11:01 PM
xteg95's Avatar
Default Re: turbo auto (MikeyDB7)
I'd convert to 5spd first I mean what's the fun of a turbo if the car is auto. But then again thats just me, I tihnk there is someone on this board who converted his auto to a 5spd and went turbo.
Old Mar 7, 2003 | 12:09 AM
TerribleOne's Avatar
Default Re: turbo auto (xintegra01)
**** automagic...
Old Mar 7, 2003 | 04:09 AM
smdandb2's Avatar
Default Re: turbo auto (TerribleOne)
In competitive 1/4 drag racing, and auto car will be better. A HELL of a lot more consistant. Unless you are a pro who shifts perfectly, and the correct RPM, every time... the auto will be more consistant.
Not to mention killer 60ft times if you can spool the turbo and then launch.
Buttttttttt... I gotta add the but. For daily driving, the 5 speed will be MUCH funner!
Old Mar 7, 2003 | 05:14 AM
IC x Prince's Avatar
New User
Default Re: turbo auto (smdandb2)
my friend had a turbo ls/vtec auto...it ran 14.3 and no peel out and his car ecu was auto so it was wierd...it was all over the rev limiter...haahhaha...he fixed it buy puting an LS hydro 5speed tranny in it.
Old Mar 7, 2003 | 08:19 AM
Integra97Zeke's Avatar
yes it is
defintly convert it over to a 5 speed first.
[Modified by IntegraZeke, 11:20 AM 3/7/2003]
Old Mar 7, 2003 | 08:27 AM
G a b e's Avatar
Banned
No, because with an auto, you dont' have to lift to shift.... meaning you are on the gas even when the car is shifting.
Old Mar 7, 2003 | 10:30 AM
zojirushi's Avatar
Default Re: turbo auto (G a b e)
i'm turbo auto, no problems yet...
::knock on wood::
Old Mar 7, 2003 | 10:37 AM
PM-Performance's Avatar
Default Re: turbo auto (zojirushi)
i know a few turbo autos, they are a pain in the *** to tune on the dyno though.
lst2001 i think his name is has one and i helped him out. pain in the ***
Old Mar 7, 2003 | 10:40 AM
zojirushi's Avatar
Default Re: turbo auto (itr206)
when u dyno tune an auto, do u leave it in 2nd gear??
Old Mar 7, 2003 | 11:04 AM
wonny's Avatar
I had to make the switch from auto to manual. Your auto tranny will be taking a beating as well as sapping HP. Sooner or later, you are going to get the tranny swap either from malfunction or desire.
If you don't know how to drive stick, just get it and learn. Auto turbo sucks compared to stick.
An auto turbo teg vs a manual turbo teg with all the same component will always loose (given that the manual driver is competent). Consistency isn't an issue when the tranny just straight up sucks
But if you want to beef up your auto, buy a torque converter, upgrade your valves work and be prepared to spend a GRIP. The totaly will probably come out to a manual swap price.
Dave
Old Mar 7, 2003 | 11:12 AM
zojirushi's Avatar
Default Re: turbo auto (wonny)
the only holding me back from the 5 speed swap is the lack of funds... i don't work and i go to college.
Old Mar 7, 2003 | 11:14 AM
3rd gear on dynos equal closer to a 1:1 ratio. so best to do them in 3rd
manual dyno in 4th becuase that is as close to a 1:1 as you can get.
plus i know for a fact my car makes more power in4th on the dyno then 3rd, i got into a fight with the guy that ran the dyno contest at NOPI and showed him up becuase i knew my car and he thought he knew. . . . turned out i won the all motor class becuase of that last 4th gear pull over the prior 2 3rd gear pulls
Old Mar 7, 2003 | 11:16 AM
wonny's Avatar
Then I suggest you don't do anything until you get the funds.
If your tranny blows you are going to need a couple grand to fix it anyways. But if you wait until your tranny blows, you are in a precarious situation because you are carless.
If you can't afford it, just work hard and save money for it. I say get the swap and drive around for a little while. The price of a turbo kit or the component's of a DIY turbo kit are only getting cheaper.
Don't get yourself into a hole. Be patient and it'll pay off
Old Mar 7, 2003 | 11:30 AM
SpeedMonkeyRacing's Avatar
turbo auto is not that bad. just don't take your car to the drag track and it will last you a long long time..
oh yeah..do yourself a favor and get an tranny cooler if you do go turbo..you can find one in the junkyard fairly cheap and it will help prevent your tranny from going kaboom..
Jeff-
Old Mar 7, 2003 | 11:35 AM
Default Re: turbo auto (Corporal-Jeff)
trannys dont cost a couple grand . . **** a Spoon tranny with JDM final drive brand new shipped is only $1700.
a reg auto tranny from a teg is a couple hundred bucks.
dude you wont have any probs, you just wont put the power down that you would with stick . no biggie. either or will work .
Old Mar 7, 2003 | 11:44 AM
zojirushi's Avatar
Jeff-
i already took that precaution, i'm running on a hayden tranny cooler and neo synthetic atf. I was thinking about using maybe Redline Racing ATF.
Old Mar 7, 2003 | 03:22 PM
LStech's Avatar
hey zojirushi at what psi are you boosting on? and plus how much did it cost for your mods on ur tranny? im planning on putting turbo in an auto cuz i dont have the money to get a swap and plus auto never misshifts. thanx
Old Mar 7, 2003 | 03:35 PM
Davanca's Avatar
Zojirushi is boosting 9psi i believe.
Old Mar 7, 2003 | 03:44 PM
LStech's Avatar
Default Re: turbo auto (davanca24)
wow that's a lot for an auto~
