troubles
Old Sep 20, 2011 | 09:32 AM
Killspeed93's Avatar
Icon6 troubles
as i was on my way to pick up my brother from school i smashed on my gsr a bit but i noticed black smoke coming out of the exhaust. and today as i was speeding up on the freeway as soon as my rpms were right under 5000 the car bogged popped off gear and check engine light went on . now under first second and third gear if i go close to5k the engine continues to bogg. does anyone have any idea or has had a similar problem than this?
Old Sep 20, 2011 | 09:39 AM
GagnarTheUnruly's Avatar
Default Re: troubles
What is your CEL
Old Sep 20, 2011 | 09:40 AM
Builda'Teg_92's Avatar
Well, Did you read your codes???
^^damn ha
Old Sep 20, 2011 | 09:48 AM
lol ^^
Old Sep 20, 2011 | 09:51 AM
no im going to get that right now and see what it is im just trying to see if anyone got the same problem off the start
Old Sep 20, 2011 | 10:02 AM
thewrai6th's Avatar
Check your oil level. Low oil will prevent the VTEC solenoid from engaging, which will throw a code and put you in limp mode.
Old Sep 20, 2011 | 10:14 AM
just check code/codes and report back...
Old Sep 20, 2011 | 01:05 PM
you my friend were right on the money it was a p1259 vtec code. it was just lacking oil but now just finished the oil change and its running perfect.
Old Sep 20, 2011 | 01:41 PM
thewrai6th's Avatar
Great!
NOW DON'T EVER DO THAT AGAIN!
Old Sep 20, 2011 | 02:10 PM
will do sir! but part 2 my exhaust broke off it looks like it was corroded and so i just took it off . the car sounds amazinng! is it safe to run it without a muffler at least till i can pick up another. i have new cats in the car and everything but iv been told it could damage the exaust valves even though i see a lot of cars running straight pipe. although this isnt a full straight pipe will i be in danger till i get a new muffler?
Old Sep 21, 2011 | 08:12 AM
Detman1oh1's Avatar
Just don't blow by any cops, you should be fine til you get it fixed.
lol
Dm of mD
36Chitownrunnin
Jun 17, 2008 08:44 PM
DohctorVtec
Jan 16, 2007 05:43 AM
nosegrindR
Apr 19, 2006 11:28 AM
RonJ1969
Mar 26, 2005 06:01 PM
B3AS
May 6, 2004 10:07 AM
