Tranny issues..
Old Jan 11, 2012 | 03:11 AM
smoked08's Avatar
Default Tranny issues..
Ok so my friend has lsv integra..he jst baught a b16 tranny. when we installed it the gears were hard to engage ,so he asked the guy who he baught it from ..he told him it didn't have tranny fluid ..maybe that was case bc tranny worked fine, he jst upgraded to LSD b16 .we went to o reillys & idk why he baught some cheap tranny fluid he said jst incase tranny was bad didn't wanna spend alot on it if it was. anyways he asked someone that worked there which to get they told him to use auto/Manuel gear lubricant which he baught master pro chemicals GL-5 80w-90. when he put tranny fluid, gears were starting to slowly go in ..well whenever we installed everything he started car up..he was going to reverse it wouldnt go in so idk he went into 5th & didnt wanna come out ..if he let go of clutch you cld hear a small grind . he had to have clutch in whole time, he baught new tranny fluid syncromesh & drained out the other & filled with new eventually it popped out 1,2,3 & reserse worked & 4th & 5th were hard to go into & come out of. he noticed that when he had in neutral there would be a small grind?? Any ideas?? Also he started up car he had heard a loud pop noise like gun shot ..he checked block to see if he had any hole he didnt he then heard it another time..he thinks it might from old gas sitting in there any suggestions?
Old Jan 11, 2012 | 03:57 AM
thenoxus1's Avatar
Default Re: Tranny issues..
Please, go to school and learn to use a period. It's almost impossible to get through what you wrote. Why did he not run regular old manual trans fluid? It could be numerous things. As for the pop, where did it come from? If it sounds like it's in the exhaust, it was most likely a backfire from fuel burning up. That could be too much fuel being dumped or it not burning right.
Old Jan 11, 2012 | 04:35 AM
smoked08's Avatar
Sorry i was kinda in a hurry when typing this ..lol
Yeah thats what i had told him also maybe backfire. Any ideas tranny issues?
Old Jan 11, 2012 | 06:28 AM
fcm's Avatar
fcm
Old Fart
Sounds like the transmission has a bent shifter fork and probably other problems. 94
Old Jan 11, 2012 | 10:59 AM
smoked08's Avatar
Would a bent shift fork cause that tho
Old Jan 11, 2012 | 05:23 PM
fcm's Avatar
fcm
Old Fart
Hard shifting into gears, yes, if it will shift into gears, but grind when you do, then it is the synchromesh for those gears. 94
Old Jan 11, 2012 | 05:28 PM
Hidenplanvew's Avatar
so he put gear oil in the trans?.. Honda MTF is a motor oil not gear oil... He could of messed up the trans just using gear oil
Old Jan 11, 2012 | 06:19 PM
b20bFourDoorCivicLX's Avatar
i just recently did a auto-to manual swap on my integra, and on the tranny i bought the drain bolt was warp't . i had no choice but to j-b weld it i had to go to work the next day,I KNOW the tranny fluid ive used isnt bad, or wrong...i even tried to add some lucas to help shift smoother no help! sorry to jump on ur post but i would hope its not the synchromesh i heard its exspensive and might as well replace the tranny. how much is the shift fork? right now my only gears tough getting in to are 1-2 and its a cable tranny
Old Jan 11, 2012 | 06:25 PM
fcm's Avatar
fcm
Old Fart
http://www.acuraautomotiveparts.org/...s=&view=normal 94
Old Jan 11, 2012 | 06:28 PM
i heard its not bad to use motor oil i put 10-30 synthetic and after 20-50 motor oil. im not grinding my gears but its tough to shift, do u recommend a tranny flush? before i replace my shift fork?
durrett syndrome
Nov 21, 2003 08:50 PM
hdeuce
Sep 3, 2003 02:02 PM
Brian-Brian
Jul 22, 2003 08:56 PM
Proper
Apr 23, 2003 04:55 PM
