Traction bar install problem
Old May 4, 2012 | 10:16 AM
Dc2 Strogg's Avatar
Default Traction bar install problem
So I went to install my full-race traction bar on my Integra just earlier and I was taking the tow hooks off when one wouldn’t come off. I then found out there are nuts tack welded on the inside of the cross member holding these bolts in (I used a flashlight to peak through one of the random holes). One bolt came out fine, one bolt came out but the nut came off and is rattling inside the cross member and the other bolt is spinning in place cause the tack weld broke holding these 2 nuts on the inside. The other side tow hook came off fine. What should I do as there is no access to the inside of the cross member? Cut a slit in the bottom so I can get a wrench inside? I don’t want to ruin the structural integrity of the surrounding area as Im trying to install a traction bar.
Old May 25, 2012 | 05:38 PM
mafia's Avatar
Default Re: Traction bar install problem
No easy way out without a lot of work.
Old May 25, 2012 | 09:03 PM
Hidenplanvew's Avatar
drill a hole or whatever and just weld it back up when done.. Wont ruin anything
Old May 28, 2012 | 05:43 PM
TKERacer619's Avatar
Does it need the nut for the traction bar install? Can you just cut the damn thing off?
Mr.Death
34
Jun 30, 2013 03:51 PM
DeDonDeRosa
Apr 1, 2009 06:22 AM
thaiphob
Oct 16, 2004 04:59 PM
cursED
34
Jun 30, 2003 05:57 PM
gribbs
21
Apr 18, 2003 08:59 AM
