TPS voltage help
Old Jul 21, 2013 | 06:07 AM
BIGef's Avatar
Default TPS voltage help
I got a b18b1 motor
having trouble calibrating the TPS
i can get the .5v on closed throttle
but open throttle it goes to like 4.7 or 4.8 somewhere around there
cant get it to 4.5v exactly.
This is an 65mm throttle body.
is it because its a bigger throttle body?
Would you guys rather have 4.5v open or .5v closed.
Any help appreciated
Old Jul 21, 2013 | 07:29 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: TPS voltage help
How accurate is your meter?
Old Jul 21, 2013 | 02:31 PM
BIGef's Avatar
Not sure how accurate
Old Jul 21, 2013 | 02:37 PM
B_Swapped93's Avatar
there's room for 1 or 2 +/- as you're describing
Old Jul 21, 2013 | 02:45 PM
mike:'s Avatar
^^ TPS is well within range, is the ecu throwing a code? I would suggest checking the grounds on the thermostat, most sensors share a common ground there and mine threw codes and it ended up being the wires had stretched and pulled out of the electrical connector.
Old Jul 22, 2013 | 03:48 AM
BIGef's Avatar
alright thanks for the reply.
notice when doing partial throttle is bogs bad. but when open throttle no problems.
will tps voltage dump more fuel making it bog like that.
Old Jul 22, 2013 | 06:18 AM
S2BumpsticksGSR's Avatar
Try .47-.48 closed and see where wide open is should be 4.5-4.6 then test drive. If you don't have a lot of mods 68mm is too big. Depending on mods you might be better off w/65mm. Edit: oops, misread size. Keep in mind a stock ITR has a 64mm t/b and your head flows waaayy less air...
Old Jul 22, 2013 | 10:01 AM
BIGef's Avatar
Alright ill try that. Sorry it's not a 68mm it's actually 65mm but thanks
elynen
Honda CR-V & Element
May 25, 2018 10:51 AM
gabrielsousa
16
Nov 25, 2015 10:02 PM
Danial
Jul 10, 2012 02:34 PM
integratyper1990
Jul 16, 2009 12:19 PM
turboef90
Mar 23, 2009 10:07 AM
