TPS problem
Old Apr 23, 2020 | 09:40 AM
Bjm1118's Avatar
Default TPS problem
has anyone had an issue with not being able to adjust a TPS sensor to low enough voltage for a good idle. I put on a skunk2 alpha throttle body and the tps won't adjust enough to get the idle down. Or not throw a TPS code.
Old Apr 24, 2020 | 05:50 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: TPS problem
Did you calibrate the TPS with a volt meter to spec?
Old Apr 25, 2020 | 06:23 AM
Bjm1118's Avatar
Thats the problem. I can't adjust the tps to low enough voltage for it work properly. Its like the throttle bidy has a defect or something and it won't allow it.
Old Apr 25, 2020 | 11:16 AM
tony_2018's Avatar
Fish Twig
Did you position the tps properly?
latinracerct
Jan 10, 2008 10:21 AM
N2O INTEGRA
Sep 14, 2007 12:03 PM
92ehatch
Nov 13, 2006 02:33 PM
MsMaureen
14
Jan 24, 2005 05:32 PM
snouka
Oct 15, 2004 02:02 PM
