torque monster.
i"ve got a 95 integra ls... i wanna build a motor with rediculous torque... ive been doin a bunch of research and im not sure what will work with what... ive got p29 pistons and the motor im starting with has 96k on it... ive found so far the way to go is gonna be b18 block with gsr crank and rods??? help pls! i dont wanna drop off the chart on hp either... so im stuck, pls help!
There is no such thing as rediculous torque when it comes to Hondas, but then again, it's all relevent. The best way to create some nice torque would be a decently built turbo application. I can't see any really high numbers that you could compare to a turbo app even with a good NA build.
you cant put a gsr crank in an ls b series. has to be b18c. the 2 cranks are different. and as far as more torque w/o boost just build your block up and maybe tune it to more low end power
OP, are you gonna be doing circuit racing? Look into a transmission upgrade, i.e. B16, ITR or aftermarket gears and final drive.
TruePlayaz114
Jun 6, 2002 01:57 AM
