Too many backfires
Old Apr 19, 2018 | 02:37 PM
Tubbers530's Avatar
Default Too many backfires
So currently having another issue once again 1995 integra b20 swapped non vtec so yesterday I i was changing spark plugs bc I’ve been miss firing a lot lately and I replaced them yesterday and my car still back fires like crazy I don’t know what the issue is my cousins told me it was the spark plugs but apparently not anybody got an answer?
Old Apr 19, 2018 | 06:14 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Too many backfires
Make sure your spark plugs are gapped properly.
Remove the valve cover and confirm the mechanical timing is right and cam gears line up at TDC
Grab a timing gun and check if the ignition timing is correct
All these are very easy to do and a timing gun cost less than $20 at Harbor freight.
Old Apr 20, 2018 | 09:18 AM
CandyRedRC46's Avatar
^^^^^^ All very good advice. Also, while you're in there, you should probably check your valve lash too.
Old Apr 20, 2018 | 09:51 AM
Tubbers530's Avatar
Thanks for the help guys but it appears to be the fuel pressure regulator crossing fingers it is , if not it’s my fuel pump
lolv8s
Dec 1, 2016 06:58 AM
Brandeno
May 31, 2015 08:55 AM
SupraRXZ
Feb 24, 2006 04:31 PM
Layziebtnh055
Aug 24, 2004 08:32 AM
ludetech
May 20, 2004 10:33 AM
