tire size????
Old May 21, 2002 | 05:42 PM
Doogie Howser's Avatar
Default tire size????
will a tire with the size 205/40 fit rota slipstreams, does the rim offset have to be the same size as the tire, because i think slipstreams are 45 and the tires i have are 40?/ thanks for the help
Old May 21, 2002 | 05:49 PM
Default Re: tire size???? (**** face)
i have 16inch rims with 205/40/16 brand new tires and i want to get some 16rota slipstreams, i am wondering if my tires will fit the slipstreams
Old May 21, 2002 | 05:53 PM
GSRrR's Avatar
Default Re: tire size???? (mlambrecht)
yes it would fit.
Old May 21, 2002 | 05:54 PM
jgrotkier's Avatar
yeah, 16" tires fit on 16" wheels.
Old May 21, 2002 | 06:22 PM
i know 16inch tires will fit 16inch wheels....im saying with the 40offset on the tires fit the 45offset on the rims
Old May 21, 2002 | 06:40 PM
jgrotkier's Avatar
I think you are reading the numbers wrong. That 40 number on the tire is not an offset, its the ratio of the sidewall width compared to the width of the tread (the 205). Here, read up
http://www.tirerack.com/tires/tiretech/general/size.htm
Old May 22, 2002 | 05:31 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: tire size???? (jgrotkier)
They will fit, but 205/40 is much too small for a 16" wheel on a Teg. It will throw your speedometer off, it will register more miles on your car than you actually drive, it will lower fuel economy, and you will have more fender gap than you did w/ stock tires. 205/45-16 would be a better choice.
highneo
Apr 10, 2007 11:22 PM
icefirezero
Feb 21, 2006 04:04 PM
BuyImports2
Mar 19, 2005 04:35 PM
Cone
Apr 1, 2003 11:24 PM
jonsteR
Aug 23, 2002 12:51 PM
