tips on changing head gasket
Old Sep 19, 2002 | 04:48 AM
311's Avatar
311
Default tips on changing head gasket
I know how do do everything except making sure the timing belt is timmed right when i put the head back on. any suggestions on how i can mark the timing belt to properly align the timing?
Old Sep 19, 2002 | 06:28 AM
311's Avatar
311
Default Re: tips on changing head gasket (311)
bump
Old Sep 19, 2002 | 06:42 AM
Audi A4's Avatar
yah mark it with some white out , mark the belt with the gear.
Old Sep 19, 2002 | 09:11 AM
Shft@9GSR's Avatar
easiest way is to make sure the motor is at tdc when you take it apart. The timing marks on both cams will line up together in the middle )- -(
When you put the cams back in, just make sure the marks are back pointing at each other.
I've done both the tdc way and the marking the belt and gears. My opinion is the tdc way is best/easiest.
Old Sep 19, 2002 | 09:13 AM
Stewie's Avatar
Default Re: tips on changing head gasket (Shft@9GSR)
Make you line up the crank with the mark on the timing belt cover and not the one on the block.
Old Sep 19, 2002 | 09:48 AM
311's Avatar
311
Default Re: tips on changing head gasket (Mac8008)
thanks!
Old Sep 20, 2002 | 08:20 AM
94b16civiccoupe's Avatar
hey man this is the guy that talked to you on the phone about your turbo kit. im coming to nopi tomorrow and i want to meet up to buy the turbo. call me at 770-842-1244. before tomorrow. thanks
alx_90ef
Apr 25, 2011 02:12 PM
yc_dc4mar
Jul 6, 2008 05:49 PM
Boostedb20EH2
10
Mar 10, 2008 04:36 PM
efyou
Jul 1, 2006 10:07 AM
fro
Dec 21, 2004 12:56 PM
