Tips for breaking-in a head
Old May 23, 2008 | 07:29 AM
StraightNoChaser's Avatar
Default Tips for breaking-in a head
The shop's finally done with my head so I'll be putting it on tonight. Since I couldn't find someone local to port it, all they did was a valve job and clean it. Is there anything special that needs to be done to get it ready? Or, anything that should be done after it's put back together?
Old May 23, 2008 | 09:02 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Tips for breaking-in a head (StraightNoChaser)
Apply assembly lube to the cam journals, rocker arms, and valve stem tips. They should have greased the valve guides. Prepare to crop dust when you fire it up.
Old May 23, 2008 | 09:35 AM
inspiration's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StraightNoChaser &raquo;</TD></TR><TR><TD CLASS="quote">The shop's finally done with my head so I'll be putting it on tonight. Since I couldn't find someone local to port it, all they did was a valve job and clean it. Is there anything special that needs to be done to get it ready? Or, anything that should be done after it's put back together?</TD></TR></TABLE>
Putting back together a head. Doesn't really take much to it. It's all about just putting enough lube on the camshaft journals, you have to put Honda bond on those rings that goes around the camshaft. I'm not sure what it is called. Someone here should be able to correct me on this.
Old May 23, 2008 | 10:04 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Make sure you clean out any oil &/or coolant that may have gotten down into the head bolt holes. (its much easier to dip a rag down there while the head is off the car)
As far as break in, there's nothing special you need to do once its on and you get it running. You might want to change the oil a bit sooner than the 3k mark for you first post-headjob oil change.
Old May 23, 2008 | 10:48 AM
Default Re: Tips for breaking-in a head (Tim2179)
Thanks for all the help. I've already made a short "To Do" list. Now, I'm on my way to google "Honda bond."
Old May 23, 2008 | 11:01 AM
steveo135's Avatar
i just picked som eup from acura
Old May 23, 2008 | 12:24 PM
projectTeG's Avatar
umm make sure everything thing is lubed, prime the oil system(disconnect dizzy, unplug ecu fuse....crank engine for a few seconds) then run listen for noises, drive for a while, then let cool and check valve clearance. are your cams or rockeres new? if not then there is no need for a break in on the old componets.
new cams and rockers your let idle at 2k for about 15-20 mins.
Old May 23, 2008 | 01:05 PM
Default Re: (projectTeG)
Could I use something else besides Honda Bond? I really need to finish this tonight and I don't think I can acquire any in time. I did manage to come across some Crower 402s but couldn't find any springs/retainers so I'm going to wait on those. I've never primed an oil pump, but it dosen't sound too hard. You just unplug the distributor, pull the ECU fuse and try to start it a few times?
Old May 23, 2008 | 01:32 PM
projectTeG's Avatar
Default Re: (StraightNoChaser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StraightNoChaser &raquo;</TD></TR><TR><TD CLASS="quote">Could I use something else besides Honda Bond? I really need to finish this tonight and I don't think I can acquire any in time. I did manage to come across some Crower 402s but couldn't find any springs/retainers so I'm going to wait on those. I've never primed an oil pump, but it dosen't sound too hard. You just unplug the distributor, pull the ECU fuse and try to start it a few times?</TD></TR></TABLE>
yup just crank it to get oil back into the head, you can use rtv sealant too.
unknown0001
11
May 11, 2007 03:43 PM
K2e2vin
Nov 26, 2006 09:02 AM
SVOboy
19
Jun 22, 2006 05:30 PM
EFMAN
13
Apr 10, 2006 07:49 PM
WHATS VTEC
Jan 24, 2004 10:10 AM
