timing help
Subscribe
Oct 7, 2005 | 07:25 AM
i need help with my 1994 integra rs. i just bought it and the guy had the fuel pressure up to 61psi and thats way to high, so i turned down the pressure. now the timing is also retarded all the way so can someone help me and give me the timing specs and give me a wiring diagram so i can time it correctly
Reply 0
Oct 7, 2005 | 10:27 AM
Re: timing help (stewmasterk)
The spec is 16 +/- 2 degrees BTDC. You don't need any sort of wiring diagram. All you need is a timing light and a paper clip or small piece of wire to jump the service connector.
Reply 0
Oct 7, 2005 | 03:09 PM
Re: timing help (Padawan)
where is the service connector located at?
Reply 0
Oct 7, 2005 | 03:30 PM
passenger side kick panel. Should look similar to the one pictured in this thread:
https://honda-tech.com/zerothread?id=1171263
Although your's may be blue, and it may be in a green or blue rubber socket.
Reply 0
Subscribe
