TEIN SS PROBLEMS ON INSTALLATION HELP!!!!!! ASAP
at the moment im installing my tein ss's on my 2000 Integra GSR and i have came across a problem.. the fronts are doen and as i started to lower the car on the jack the shock rod started riseing (the rubberbushing and washer and nut) lifted if my hood was closed it would of put a hude dent in them..... i think i have conquered that problem but now i have a knocking noise coming from the driver side.. all bolts are tighten it sounds like its coming from the top of the shock assembally. please help me thanks
sorry to post this in different spots i need this fixed soon!
If its making that knocking noise while your driving (you didnt say) it might be because at the point where the springs are closest they are banging together as you go over bumps. You can use some rubber sleeves that go around the spring (I'm not sure of the name).
yes its when driveing i dont think its the coils of the spring touching eachother cause if you push on the car to make it bouce it knocks... grrr this sux lol thank you guys for your fast replys
Nism05
Jan 3, 2007 11:41 PM
jdmwestcoaststyle
Suspension & Brakes
Sep 27, 2005 04:32 AM
JDM-FREAK
Sep 15, 2002 10:11 AM
