TEIN HA install
Old Jun 1, 2002 | 01:08 PM
JDC2's Avatar
Default TEIN HA install
What do you guys think installing the TIEN type HA on a integra would cost? I have the lower control arms too. I got some quotes on the install and they range from 70~350 bucks depending on where you go! any info would be helpful. Thanks!
Old Jun 1, 2002 | 01:21 PM
IN VTEC's Avatar
Default Re: TEIN HA install (JDC2)
Since it's only a simple strut removal and replacement, it should take no longer than 45 minutes to an hour's labor...hour and a half at most. As long as you have an impact wrench handy, it's a really simple procedure.
Old Jun 1, 2002 | 01:30 PM
GSpeedR's Avatar
Default Re: TEIN HA install (IN VTEC)
It's really not that hard of an installation. I would say a shop can do it in an hour and you could do it in 2 hours with impact wrench 3 hours without.
Old Jun 1, 2002 | 02:25 PM
PaChiLa Leader's Avatar
Default Re: TEIN HA install (GSpeedR)
I thought the newer model HA doesn't need LCA anymore...???
Old Jun 1, 2002 | 02:31 PM
JDC2's Avatar
Default Re: TEIN HA install (PaChiLa Leader)
I got the ITR model which requires the LCA's.
Old Jun 1, 2002 | 04:18 PM
integra-modder's Avatar
arent the ITR LCA's good quality metal as oppose to the other tegs?
Old Jun 1, 2002 | 06:59 PM
Vitt1's Avatar
$70 to $100 is about a fair price. Are they already assembled? If so, it won't take that long at all at a shop with power tools.
Old Jun 1, 2002 | 09:57 PM
primoEF's Avatar
Default Re: TEIN HA install (Vitt1)
an hour the most, i guess shops usually charge more for coilovers cause they have to adjust the height after, not like springs and shocks you don't have to adjust anything
Old Jun 1, 2002 | 10:46 PM
Asahi's Avatar
Default Re: TEIN HA install (b18k1)
I will take a shop more than 1 hour. THey will have to compress the springs and reuse the suspension caps. Figure about 2 hours as a good time frame.
http://www.bseries.net/html/garage/spring.php
Old Jun 2, 2002 | 06:01 AM
IN VTEC's Avatar
Default Re: TEIN HA install (Asahi)
I didn't remember to think about that. But, if you get the optional pillowball mounts, then you wouldn't have to remove and reuse the spring hats.
Old Jun 2, 2002 | 07:49 AM
uNF$@#!'s Avatar
when i took out my springs for spring replacement...took me a little over 10 hours to do
Old Jun 2, 2002 | 08:20 AM
sutrusu's Avatar
Default Re: TEIN HA install (00-0187)
good lord. i'm glad i paid the shop to do mine, cuz they had my ground control and agx install done in 2 hours.
Old Jun 2, 2002 | 08:31 AM
JDC2's Avatar
Default Re: TEIN HA install (sutrusu)
so you guys don't think that installing the LCA's along with the coilovers wouldn't be that hard for a shop to install??
Old Jun 2, 2002 | 09:20 AM
IN VTEC's Avatar
LOL. It's not supposed to be marathon sport fool. Heh.
As a reference point for comparison, I can have the front coilover assemblies laid out in pieces in less than 30 minutes if I have the proper tools. It's even less time for the rear.
Putting it back together gets kinda uncertain b/c I can't always get the rear, outer LCA bolt lined up and threaded the first time. Same thing with the front shock fork.
But, yes, it should be a quick and easy job. Wish I could fly out there and help you.
Old Jun 2, 2002 | 09:36 AM
primoEF's Avatar
it should be a piece of cake for any shops that know Hondas. Unless your suspension is all rusted up and all the bolts are not comming out then it becomes pain in the butt
Old Jun 2, 2002 | 02:26 PM
S13 slide's Avatar
do it your self, i threw my Ha's on my S13 in about 30 minutes after it was all assembled with the upper pillow ball mount and every thing adjusted, my teins are soo dope. gotta love em
Old Jun 2, 2002 | 03:54 PM
Jackson's Avatar
I will do it for $60 if you are in so cal.
Old Jun 2, 2002 | 07:44 PM
JDC2's Avatar
Default Re: TEIN HA install (Jedi Master)
what shop are you from?
Old Jun 2, 2002 | 08:17 PM
Jackson's Avatar
http://www.DoItYourself.com
Old Jun 2, 2002 | 08:23 PM
JDC2's Avatar
WOW, i've nothing but good things from there! but seriously if you have the right tools and the know how i'm down. Plus i would like to help out too and learn something new.
madjdmek9
Sep 23, 2008 10:05 AM
SomeDude56
Aug 21, 2006 06:13 PM
