Teg Build
Old Apr 27, 2010 | 08:06 AM
Red-Rag-B18's Avatar
Default Teg Build
I got 3 gz sitting next to my ls teg. i plan to stay ls and no boost. any suggestions on where to start?
Old Apr 27, 2010 | 08:41 AM
AcuraLsSE's Avatar
Default Re: Teg Build
I/H/E, engine management, suspension, clutch and flywheel.
Old Apr 27, 2010 | 12:56 PM
WDG_729_ITR's Avatar
If you want to make good power, you would probably want to look into getting higher compression pistons, and ITB's (Individual Throttle Bodies) are good for N/A builds. You'll also want to get some good Cams. Intake, Header, Exhaust, Individual Throttle Bodies, Cams, Spark Plugs/Ignition System (MSD is good), and you could even upgrade the injectors (not too much--remember that it's only an N/A build). Then, purchase a better engine management system, and get it tuned. If I were you, I would invest in boosting it. If it was a GSR or Type-R, then I would be more prone to staying N/A, but since it's an LS, I would do a mild build (Pistons, Rods, etc.), and then invest in a turbo kit (personally).
Old Apr 27, 2010 | 01:04 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
"3 gz"? Is that supposed to indicate your budget? If so, stop typing/talking gansta And if so, that's not going to get you very far if you're looking for HP gains.
Best bet is to just throw it into suspension and tires and make it a monster-handling car, then save up more and focus on engine/HP later.
Old Apr 27, 2010 | 07:06 PM
luck4rmkc's Avatar
might want to give some sort of power goal or other ideas of what you are actually wanting if you are looking for suggestions
Old Apr 27, 2010 | 11:10 PM
coquieg6's Avatar
yo i got 3gz to buy some ho's n a gun n rob da mugen shop lol. its cool to use 3gz in my book.
Old Apr 27, 2010 | 11:33 PM
TonyRomo's Avatar
ITBs for DD?
Old Apr 28, 2010 | 07:04 AM
Originally Posted by TonyRomo
ITBs for DD?
It all depends on what your power goals are.
Old Apr 28, 2010 | 07:27 AM
GagnarTheUnruly's Avatar
ITB = DD fail especially for LS where the mid to low end is already practically nonexistent on a build revving high enough to need ITBs. IMO there is very little point in doing an all-motor build on a non-VTEC LS. Either save for FI or stick with handling mods as PatrickGSR recommends. That's my opinion.
Old Apr 28, 2010 | 02:08 PM
Thank you. That's kinda what I said there at the end of my post--that since it's not a GSR or Type-R, it wouldn't be a good idea to invest in a N/A build. I simply suggested ITB's because they provide a pretty decent power gain.
TVietEBoyG
Aug 19, 2007 08:08 PM
wernhersey
Jul 9, 2006 08:43 PM
g0lden
Mar 2, 2005 06:06 PM
integra81
Nov 19, 2001 05:59 PM
