technical build help b18c1
Old Feb 10, 2010 | 02:43 PM
b18cdelsol's Avatar
Default technical build help b18c1
I was wondering if anyone here try this out yet. I have a 95 b18c1 motor which i'm planning to build. 84mm sleeves block, 5.531 gsr rod length, standard 87mm stroke. I'm doing a 12:1 CR NA motor of course. Here is what i want to know, how much of a difference will a 1.61 r/s ratio compare to a 1.58 r/s ratio make? will it help out with higher revving? or is it better doing a reverse vtec ls? ls rotating assembly in a gsr block. Let me know what you guys think.
Old Feb 11, 2010 | 03:29 PM
b18cdelsol's Avatar
Default Re: technical build help b18c1
anyone?
Old Feb 11, 2010 | 03:36 PM
racebum's Avatar
rod ratios that close aren't even worth worrying about.
the all motor forum will be more help than here
if you run 12:1 on pump gas forged pistons with coated tops and a reshaped combustion chamber from someone like endyn will make the car a lot easier to give timing.
other thoughts. get as much displacement from the build as you can. the dart blocks are also superior to any sleeved block i have seen. i would price both.
Old Feb 12, 2010 | 11:54 AM
b18cdelsol's Avatar
thanks for the reply
youngyankee585
Jan 6, 2014 08:23 PM
PerikoBubble13
Dec 13, 2006 11:10 PM
Demon_Dub
14
Feb 17, 2006 06:26 AM
Imadreamer1226
Aug 27, 2003 03:01 PM
spoolin342
Feb 7, 2002 09:39 AM
