Taillight question....
my taillights dont work and also my dash lighting where the rpm's r...like when i drive at night i cant see how fast im goin and i hope i dont get caught by the cops cuz i got no taillights at nite... ....the bulbs are fine...and i was wondering wut could b the problem....fuses??? wut u guys think?? my headlihgts work fine
my buddy had a similar problem which was caused by a wire for one of the bulbs being pinched between the taillight housing and the frame of the car causing a short. but yea check your fuses.
Each tailight has a seperate control module.
Grab a friend who has a DC and take their control module to see if you get your tailights back.
Im not sure about your cluster. You're gonna have to get that looked at.
I had the same problems, and ummm ok..
1. Have you changed or anyone changed anything electrical in your car ? (my problem was the radio)
2. Any loose wiring running from the tailights up to the front ?
3. Any cuts/splices on the wires ?
yeeeah. Well what my proble was, I pinched one of the wires with the radio support, which caused a short on the electrical wiring, and blew my fuses. <3
GGkTHX
sounds good ? sounds right to me...
GGkTHX
in the engine bay there is a fuse called back up fuse. reading it might make u think it is for the reverse light but it is not check and replace that, same thing happened to me and i replaced that fuse and it worked mint, let me kno it that works
Check the underhood fuse #51. See diagram underhood diagram below. The Helms states:
Fuse Number: 51
Fuse Name: +B Small
Amps: 15
Component: Dash and console lights, Licence plate lights, Rear parking lights, taillights
Check the two underdash fuses #30 (instrument lights) 7.5 amps and #32 (licences/taillights) 10 amps.
Also check the the fuses amps rating, if its higher that the stated values and did not blow, then there's a short somewhere and it didn't trip the fuses due the the higher amp rating. That's why you don't ever use a higher amp fuse than the needed value.
If that don't work, get a Helms manual and a multimeter and look for the short!
Fuse Number: 51
Fuse Name: +B Small
Amps: 15
alrite i changed number 51 and the dash console lights work now so thats a good start...but i changed number 32 and my taillights still dont work....help!!!
i bet you keep blowing the tail light fuse...aftermarket radio right? check the wiring..thats the most common reason ive seen for these symptoms
check for any frayed wires..basically any exposed wire..use black electrical tape to cover them up..they may be making contact with metal causing a short and blowing the fuse
theres spliced wires in the bay nex to the Power steering rite near the healight ground...its touching metal so i should put eletrical tape???
tape up any bare wire..you will know if something looks out of place and needs to be taped..sounds like you are lookin under the hood..take a look behind the radio itself..im sure there are plenty of spliced wires just yearning to be taped up behind there
ok this is real weird...i juss came from outside and everytime i change the taillight fuse it blows when i turn on the lights...this happened 3 times in a row...3 fuses gone!!!...
