Synchro's in 1st and Reverse?
Old Nov 24, 2003 | 01:32 PM
GSR_Fan's Avatar
Default Synchro's in 1st and Reverse?
I called up my local dealership and mentioned that since they replaced the master clutch cylinder that it was a bit more difficult to get the car into first, second and reverse.
I know many cars have issues getting into first and reverse, however, should it be tough to get into 2nd gear? This is irrespective of the temperature outside.
I have 2000 GS-R with 43,000 miles.
Old Nov 24, 2003 | 03:10 PM
B2FiNiTY's Avatar
Default Re: Synchro's in 1st and Reverse? (GSR_Fan)
Reverse does not have a syncro.
It should have relatively no issues getting in and out of gears. Very low mileage too.
Old Nov 25, 2003 | 03:44 AM
JimBlake's Avatar
Default Re: Synchro's in 1st and Reverse? (B2FiNiTY)
Does it get better if you pump the clutch? That would be if there's air in the lines.
1st & 2nd are on opposite sides of the same synchro hub. So maybe something messed up in common for those. Reverse doesn't have a synchro.
Old Nov 25, 2003 | 04:08 AM
Dee's Avatar
Dee
Default Re: Synchro's in 1st and Reverse? (JimBlake)
Reverse does not have a synchro but if the 5th gear/reverse gear slider gets banged up you will lose reverse gear.
Old Nov 25, 2003 | 04:56 AM
fivespeedintegra's Avatar
many manual cars have some issues getting into first and reverse from a dead stop. happens every once and a while to me, and i just put it back in neutral, clutch out, and clutch back in....works every time. that or if reverse acts up, i just pop it in 4th quick and then to reverse.
Old Nov 25, 2003 | 01:34 PM
GSR_Fan's Avatar
Default Re: (fivespeedintegra)
True. The first/reverse issue generally happens when I'm at a stop.
Going into second occurs infrequently. However, it happens when I'm driving.
Worth a call to the dealership (still under warranty). Should I ask for them to address something specifically?
Old Nov 25, 2003 | 01:41 PM
2muchGT's Avatar
Default Re: (GSR_Fan)
get a ctr tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR_Fan &raquo;</TD></TR><TR><TD CLASS="quote">True. The first/reverse issue generally happens when I'm at a stop.
Worth a call to the dealership (still under warranty). Should I ask for them to address something specifically?</TD></TR></TABLE>
i used to have that issue....every once and a while if i was going into a turn and would try to shift into second, it just wouldn't go. i changed my tranny fluid to GM synchromesh and it hasn't happened ever since. when's the last time you changed the fluid?
donepps
Apr 6, 2013 09:36 AM
KekahaB18
May 15, 2005 09:17 PM
ITR111
Mar 15, 2002 06:09 AM
Tweakmeister
Jan 14, 2002 05:39 PM
Type R 702
Nov 19, 2001 01:25 PM
