swap help please
Old Aug 14, 2011 | 02:30 PM
boostNjuice's Avatar
Default swap help please
Ran into a few problems if anyone can lend a hand.
1. On the driver side the bolt on the hub which attaches to the low control arm is spinning.. i cannot get my crown nut onto it, what to do I do?
2. The axles will only go in one way as far as driver/passenger I believe right? Because I am having a difficult time getting the passenger axle into the half shaft, did I maybe stick the pass axle into driver side lol
if anyone could shed some light it would be great
Old Aug 20, 2011 | 10:28 AM
FF for Life's Avatar
Default Re: swap help please
1. to get that lower ball joint nut to stop spinning, put another jack under that control arm and jack it up so there is a load pressing the control arm into the ball joint. Should be good then, dont be cheap and make sure you put a cotter pin in the castlated nut because if that comes apart while your driving down the road, your gunna have a bad day.
2. look at your axles side by side and see if they are identical. Make sure the splines are lined up, sometimes these can be a pain to get in all the way because of the c-clips on the tip of the axle
jmvtec05
Honda Civic (2001 - 2005)
Aug 11, 2012 09:25 PM
boostNjuice
21
Aug 18, 2011 12:21 PM
boostNjuice
Aug 15, 2011 09:03 AM
gursh d
Jan 23, 2007 09:21 AM
CRX_Control
Aug 8, 2005 03:26 PM
