Suspension question: Shocks
I just dropped my '98 gsr w/some RS*R Down Springs w/stock shocks and it sorta "slammed" it. My question is when I install a stronger performance shock, will it raise it a bit? The drop on the spring is 1.5. Also, what is a good affordable shock out there? Thanks!
the aftermarket shocks are not going to raise it, they will just not rebound like a stock one would on a bump. it is a much more solid shock. i would suggest for a drop like that to get koni yellows, tokico illuminas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drian »</TD></TR><TR><TD CLASS="quote">I just dropped my '98 gsr w/some RS*R Down Springs w/stock shocks and it sorta "slammed" it. My question is when I install a stronger performance shock, will it raise it a bit? The drop on the spring is 1.5. Also, what is a good affordable shock out there? Thanks!</TD></TR></TABLE>
You didnt happen to buy those off of houston-imports did you?
