suspension help
Old Dec 14, 2004 | 11:30 PM
jreyno1's Avatar
Default suspension help
i have skunk 2 coil overs on my 96 integra gsr but the thing i hate is that when dirt gets inside them they are so hard to adjust. what kind of suspension do u guys think would be better for my car that would give me good performance?
Old Dec 15, 2004 | 01:44 PM
OneDirection's Avatar
Default Re: suspension help (jreyno1)
I have ground control and I like them. They are fairly easy to adjust, I just jack the car up and use a spray bottle with water and a touch of soap on them to clean out the grime before adjusting them. Combine these with Koni Yellows and a good sway you should be handling beautifully. Keep in mind you should be setting and forgetting your suspension settings for the most part. IE you will tweak them a bit to get the proper corner weighting/travel/springs/etc... But once you have them right, you want to leave them where they are as you need an alignment everytime you change ride height.
EDIT: (out of posts for the day) I don't know about Skunk2, but GC recommends not using WD40 or any lubricant, just water. I only add soap (dawn) to help break down any oil based road grime.
Modified by OneDirection at 4:09 PM 12/15/2004
Old Dec 15, 2004 | 02:45 PM
skunk2eg's Avatar
ive had that problem...spray em with brake cleaner or wd 40, its a little tight at first but loosens up...good luck
1999siguy
Suspension & Brakes
30
May 28, 2009 12:58 AM
B16aCRXSi
Jan 30, 2009 08:38 AM
BAYxlude88
Sep 28, 2008 09:49 AM
yellowturbo
Dec 27, 2004 10:25 AM
