suspension!
Old Dec 18, 2007 | 08:21 PM
zhen_fai's Avatar
Default suspension!
i want to change my suspension, the coil spring and shock absover.
but cant design what to buy yet
98 gsr!!!!chicago road condition, which is shitty condition!
Old Dec 19, 2007 | 06:39 PM
dickdragon's Avatar
Default Re: suspension! (zhen_fai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zhen_fai &raquo;</TD></TR><TR><TD CLASS="quote">i want to change my suspension, the coil spring and shock absover.
98 gsr!!!!chicago road condition, which is shitty condition!</TD></TR></TABLE>
you're a suspension designer?
Old Dec 19, 2007 | 07:43 PM
PrinceAli132's Avatar
If its not going to see any track use then I would consider some Koni Yellows/Ground Control Coilovers or PIC Apex. If you can afford it and/or will be tracking your car in the future then PIC Select or Koni Yellows and Ground Control Coilovers.
Also, search there is a ton of info around here.
Ali
Old Dec 19, 2007 | 07:49 PM
goodtrouble's Avatar
Default Re: suspension! (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote"> I would consider some Koni Yellows/Ground Control Coilovers or PIC Apex Ali</TD></TR></TABLE>
x2
crazykamper
Mar 4, 2011 07:12 PM
jtbsurfer
Aug 29, 2007 12:35 PM
Jaydem02
Suspension & Brakes
Feb 11, 2006 02:26 PM
AP_TWO
Dec 19, 2005 07:16 PM
lsracer27
Suspension & Brakes
11
Dec 17, 2005 07:09 AM
