Strut bar problems with skunk2 itm install
Old Jan 9, 2002 | 07:57 AM
comptechgsr's Avatar
Default Strut bar problems with skunk2 itm install
with the skunk2 itm installed, (using the stock gsr tb cable and gsr tb) the strut tower bar will not fit...
does anyone know where i can buy the "butterfly/rotating thing" that connects to the throttle body cable? I have the itr throttle body cable (uninstalled) but need that one part that it connects to on the throttle body.
again, what is this part and where do i get it? it's like a springy rotating thing....
haha, thanks
Old Jan 9, 2002 | 12:56 PM
alexboy's Avatar
Default Re: Strut bar problems with skunk2 itm install (comptechgsr)
Put the bar backwards that is what i did. It occasionally rubs though
Old Jan 9, 2002 | 03:48 PM
CKim's Avatar
Default Re: Strut bar problems with skunk2 itm install (alexboy)
Or get a different bar.
I switched a spoon front STB when my comptech wouldn't clear my AEM FPR (JR's FP mounting plate pushed the FPR up just enough so that it wouldn't clear).
Old Jan 9, 2002 | 05:58 PM
Default Re: Strut bar problems with skunk2 itm install (CKim)
tried the backwards trick....rubs...
anyone else have a solution?
which Strut Bar works?!?!
Old Jan 9, 2002 | 06:40 PM
rockwilda's Avatar
i know the Tanabe bar works....a guy at the shop i go to uses it with his skunk2....i myself will probably go with the itr throttle cable/bracket later on
mogz
Nov 19, 2003 12:48 AM
spankaveli
Apr 3, 2002 09:42 PM
comptechgsr
Feb 23, 2002 12:25 PM
comptechgsr
Feb 18, 2002 05:20 AM
