Squeaking Noise comming from steering.
Old Jan 13, 2008 | 07:35 PM
Escuro's Avatar
Default Squeaking Noise comming from steering.
I have a 98' integra rs and it seems to make a loud squeaking noise when i turn. It only does it at low speeds. Is it the powersteering pump or possibly the steering shaft's rubber bushings are worn? any help appreciated thanks
Old Jan 13, 2008 | 08:11 PM
JDMtegg19's Avatar
Default Re: Squeaking Noise comming from steering. (Escuro)
where is the noise coming from
Old Jan 14, 2008 | 05:19 AM
DOHCter VTEC's Avatar
Default Re: Squeaking Noise comming from steering. (JDMtegg19)
I have this too, I didn't think much of it...but now sicne it's brought up. Is anythign wrong with that? As I'm pulling out of my driveway and I turn the wheel, I start hearing these noises coming from...somewhere at the wheel I say.
Old Jan 14, 2008 | 07:47 AM
AccordSleeperZzZ's Avatar
Default Re: Squeaking Noise comming from steering. (DOHCter VTEC)
had a problem thats sounds like yours. the previous owner ran the power steering pump almost dry for a while, apparently, and it squealed like hell at low speeds. i refilled the fluid, fixed the leak that was causing it to run low, and the noise went away. check the level, make sure your ps belt is tight. good luck
Old Jan 14, 2008 | 08:32 AM
integra4eva's Avatar
i had this too, i replaced my wheel bearings and everything was fine... so that migh be the case with you.. but if its not, a sqeeking would prolly mean that something is rusted.. so PB blast, or WD40 all the tie rods ...
Old Jan 14, 2008 | 10:25 AM
Escuro's Avatar
seems like the driver front wheel not sure if its passenger to. as for other replys ill check the fluid if its low ill fill it up hopefully thats the prob bec thats the cheapest one for sure lol
Old Jan 14, 2008 | 01:41 PM
which fluid are you guys refilling (sorry I'm noob)
where is the thing located?
what kind of fluid do I get?
Old Jan 14, 2008 | 07:46 PM
Escuro's Avatar
not the fluid and belt seems tight on the pump. im guessing has something to do with steering shaft?
Old Jan 14, 2008 | 08:22 PM
jhammond_82's Avatar
Reject Papi
Default Re: (Escuro)
maybe spray some belt treatment on the belt, or tighten belt?
Old Jan 15, 2008 | 10:18 AM
Escuro's Avatar
Default Re: (jhammond_82)
belt is tight
Old Jan 15, 2008 | 04:19 PM
escuro can you help me...where is this thing located? How do I check the fluid?
Old Jan 15, 2008 | 08:14 PM
Escuro's Avatar
Default Re: (DOHCter VTEC)
the power steering fluid container is at the drivers side near the headlights. \just twist off the cap to open. Youll see a diagram on the container telling you the level.
Old Jan 18, 2008 | 01:54 PM
JDMtegg19's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Escuro &raquo;</TD></TR><TR><TD CLASS="quote">seems like the driver front wheel not sure if its passenger to. </TD></TR></TABLE>
how are your breaks/rotors? also is noise the only factor or is there any wobble in the steering wheel or something else unusual
djdownfawl
Mar 26, 2008 08:24 PM
iwantspeed
Honda Civic (2001 - 2005)
Sep 13, 2006 12:23 PM
wpsadmin
Nov 15, 2004 07:38 AM
dlslvtch21
Mar 6, 2002 02:40 PM
