Spoon Cams
Old Jul 31, 2004 | 10:26 AM
95BlkGSR's Avatar
Default Spoon Cams
any1 heard anything about, these, the lift or something on them, i got a 95 GSR , i jus dont want something overpowering thats gonna sound like ****, can any1 give me some advice
Old Jul 31, 2004 | 10:59 AM
skunk2eg's Avatar
Default Re: Spoon Cams (95BlkGSR)
if its spoon, then i'm sure it must be quality.
also they will prolly be very expensive $$
Old Jul 31, 2004 | 11:00 AM
frost_0ne's Avatar
Default Re: Spoon Cams (skunk2eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2eg &raquo;</TD></TR><TR><TD CLASS="quote">if its spoon, then i'm sure it must be quality.
also they will prolly be very expensive $$</TD></TR></TABLE>
GOTTA GO WITH THIS GUY ON THAT
Old Jul 31, 2004 | 11:19 AM
au-gsr's Avatar
Default Re: Spoon Cams (frost_0ne)
SPOON CAMS ARE BUILT FOR HIGH COMPRESSION ENGINES. THEY ARE ACTUALLy reground oem units. they grnd the bottoms down to increase lift and duration. the rules of the jgtc dictate that they use stock equipment from the original powerplant. these are one of the only cams you can get your hands on that have amore aggressive primary lobe on it than a stock gsr. just to let you know the stock itr primary lobe is smaller than the gsr so if you do bolt those on the engine(the itr cams) you will lose a lil low end. the only other company that i know of htat uses a higher lift and duration primary lobe than stock is Toda. either way you go, spoon or toda, you will be happy.
Old Jul 31, 2004 | 12:08 PM
95BlkGSR's Avatar
Default Re: Spoon Cams (au-gsr)
so by adding the spoon cams im not gonna get a crappy sound in ideal(1000rpm), cause my friend cause like some crazy cams, and it sounds like a freakin muscle car in ideal around 1000rpms
Old Jul 31, 2004 | 01:38 PM
au-gsr's Avatar
NOPE.
only cams such as skunk2 stage 3 toda spec c's and jun's cams have rough idles. those cams are specifically for racing applications and that is to be expected on race cars.
Old Jul 31, 2004 | 01:45 PM
sleepin91teg's Avatar
Default Re: (au-gsr)
Whats not to love about the loping idle around 1000rpm thats intimidating and most muscle car guys look at a honda thats loping at a stoplight and get an idea in their head...lope
Old Jul 31, 2004 | 02:27 PM
zad5's Avatar
au-gsr have you seen the specs on the spoon cams these are mild cams made for compression around 11.0 -11.5 around there compression. tehse cams are a good cam for daily driving they arent as peaky as most cams which is why it doesnt have a lot of peak hp. many like it but it just doesnt make enough powaA. here ill give you guys a dyno sheet
Old Jul 31, 2004 | 02:30 PM
zad5's Avatar
Default Re: (zad5)
graph from importbuilders.com
"Spoon ($1045/pr)
Specs were kindly provided by Alan Chow at A&J Racing
http://www.spoon-sports.com/
INTAKE lift - 11.53 mm, duration 256 @1mm
EXHAUST lift - 11.13 mm, duration 245 @1mm" - from team-integra.net
personally i wouldnt buy it. but it really depends on the setup you have rite now. the power you want to make. where you want your power. the money you wanna spend.
Old Jul 31, 2004 | 10:24 PM
95BlkGSR's Avatar
Default Re: (zad5)
thanks guys, and thanks Zad5 for the chart, it helps, thanks
Old Aug 12, 2004 | 10:50 PM
NAB20B's Avatar
Default Re: (95BlkGSR)
go to this website itll give you all the cam specs youll ever want.
http://www.allmotorhonda.com/t...s.htm
Old Aug 12, 2004 | 11:20 PM
JDMwhiteDC2's Avatar
Default Re: (zad5)
[QUOTE=zad5]
just wondering but dosnt a type r redline at 9? or is it just me...it would make more sense to bring it all the way up and probably make more power? just wondering...also...could tuning be a part of the low horsepower problem...granted it is all motor? sorry if im wrong tho...
Old Aug 13, 2004 | 12:37 AM
AP1_RG's Avatar
Default Re: (JDMwhiteDC2)
good info
Old Aug 13, 2004 | 07:44 AM
GeeReg's Avatar
Default Re: (JdmSirg)
Redline = 8400 Not sure why they stopped.
Old Aug 13, 2004 | 08:12 AM
garados's Avatar
Default Re: (GeeReg)
it looks as if the torque curve is dropping off like crazy after 7.5k, meaning that if they do raise the redline, it won't make any more power. Also, you can see the power falling off at 8k as well.
Old Aug 13, 2004 | 08:16 AM
smemts's Avatar
Default Re: (garados)
That graph is excellent. The name is not everything. Just because a certain part is Spoon or Mugen does not neccessarily mean that it will out perform lesser names.
Old Aug 13, 2004 | 10:09 AM
babes 99 GSR's Avatar
The sound at idle isn't something i would base a cam purchase on...
And i have to agree that the graph doesn't look very good...i have seen much better.
- Staci
Old Aug 21, 2004 | 03:31 PM
whiteyGSR's Avatar
Default Re: Spoon Cams (99GSR1980)
so if you plan on goin NA and wanna have a smooth idle and retain low-end power, stick to our stock gs-r cams basically?
Old Aug 21, 2004 | 04:29 PM
garados's Avatar
Default Re: Spoon Cams (whiteyGSR)
not really. While GSR cams are fine, there are some cams that will retain a good idle and increase power and torque all across the rev range. ITR and CTR cams will do this. I have 98 ITR cams in my gsr, and low end torque was increased noticably, not to mention a really hard pull up to redline. I will not comment on any other cams because I don't have any experience with them.
boy_hapon
Aug 22, 2005 08:16 PM
dElSleepiE
May 9, 2004 11:55 AM
EK MONEY
Nov 17, 2003 08:57 AM
cruzersi99
Aug 7, 2001 06:28 PM
