Spoiler mounting points
Old Sep 30, 2006 | 05:19 PM
slow_ls's Avatar
Default Spoiler mounting points
Right now I have the factory optional spoiler on my 2000 ls integra. I am looking to get the JDM DC ITR Carbon Fiber Spoiler that passwordjdm.com has and in its description is says that "By utilizing the factory mounting points, you can rest assured that this spoiler will fit just like a factory piece." Now does this mean I can use the mounting holes I have for my stock spoiler or are they reffering to a Type r spoiler or do they both have the same mounting holes. thanks
Old Sep 30, 2006 | 05:24 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Spoiler mounting points (slow_ls)
If it is truly the shape of the OEM ITR spoiler, it will not cover the wire harness holes in your hatch.
Old Sep 30, 2006 | 05:31 PM
slow_ls's Avatar
Yea its just like the ITR spoiler only in carbon Fiber. So this means its a no for a direct bolt one, and if so what would I have to do to mount it correctly, just get hole plugs for it?
Old Sep 30, 2006 | 05:38 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (slow_ls)
You can just plug the holes for a ghetto look. You really need to do body work to make it look right.
Old Sep 30, 2006 | 05:40 PM
slow_ls's Avatar
But I would figure that the new spoilers base would cover the hole plugs making them not visible, or is an itr spoilers base skinnier than the one on their now.
Old Sep 30, 2006 | 06:41 PM
SlammedDC2's Avatar
Semper Fidelis
I believe that buy getting an ITR spoiler will bolt up to the RS, LS, GSR spoiler holes. I think spoilerdepot.com works like that.
Old Oct 2, 2006 | 04:24 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_ls &raquo;</TD></TR><TR><TD CLASS="quote">But I would figure that the new spoilers base would cover the hole plugs making them not visible, or is an itr spoilers base skinnier than the one on their now.</TD></TR></TABLE>
The base on the ITR spoiler is thinner because it does not have to accomodate the wire harness for the brake light. The normal spoiler has a widened base to cover to wire holes. Check out the picture:
You can see the two extra holes that will not be covered.
Old Oct 2, 2006 | 05:30 AM
OMG THE GOGGLES's Avatar
Default Re: (SlammedDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 &raquo;</TD></TR><TR><TD CLASS="quote">I believe that buy getting an ITR spoiler will bolt up to the RS, LS, GSR spoiler holes. I think spoilerdepot.com works like that.</TD></TR></TABLE>
It will however it will not have that big dookie hole covered. The only surefire way to do this is to get those stamped holes welded in and the hatch repainted, or, the best route, buy a used hatch the same color as your cars current state, from an RS/LS. One with the INTERNAL third brake light to stay legal, and then, drill your own holes. This way, you avoid the giant wireharness holes, and you get a true 3rd brakelight.
TegLover09
Jul 21, 2009 04:31 AM
xxalpridexx
Jan 8, 2008 09:11 PM
OnePointFive
Oct 4, 2007 11:54 AM
Ruben19
35
Sep 6, 2007 07:52 AM
vtec770
Sep 3, 2005 03:37 AM
